so i learned that my caps on my lcd are made by capxon any suggestions on what i should upgrade them to? Cause i have this feeling they are going to blow soon.
Cap suggestions
Re: Cap suggestions
CapXon makes many different caps.
Need Series name, diameter and length to look up the specs.Mann-Made Global Warming.
- Dr Seuss
Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
1 x Capxon 1000uf35v...-
by socketaI bought a dead motherboard, and connected it to this PSU,
Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
So now i truly got a bang for my bucks, and something else to try and fix.
The fuse was blowen, and the top was blowen off of a TNY276PN chip
The glass fuse didn't have any marking to say if it was fast or slow blow
So i checked the marking on the PCB thinking that that would tell me,
but it 's got a T/F8A printed on the board
So should i get a fast blow fuse, or should... -
by ohrenI had a switching transistor and PWM IC blow up as part of a repair, where a big chunk of each went missing. Now I would like to understand the likely turn of events, and maybe determine if I did something stupid. If nothing else, I should at least extract some lessons from it.
"IC10" can be found on page 169 in the service manual:
https://www.manualslib.com/download/...n-Mas-101.html
The entirety of the repair is basically:
1. Device doesn't power on (IC10 supply voltage unstable)
2. Replaced C18 and C66
3. Device works... -
by momakaFor today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
http://www.rmac.kingwin.com/products.../abt_650MM.asp
I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
What mostly drew me into buying it is its 2x PCI-E power connectors... -
by kokosHi to all of yoy!
I have a damaged HP PSU p/n: 901760-002 with blow up 6.3 Slow blow Fuse & an smd shorted diode with LT6B36 printed on it!
I cannot find any info on this part.
Any suggestions?
May I substitude with any similar one?... - Loading...
