Ok so i have a 23" LCD TFT HP monitor, with a backlight problem. The backlight comes on for about a second, then goes off. It does this a second time about 45sec. to a minute later and then the screen goes into stby mode. The LCD panel itself works, as i can see images when i hold a flashlight up to the LCD. I have changed all the caps in the power circuit, even though none of them showed signs of being bad. I have tested power at the, large filter cap, and at the bridge rectifier, both test good. Im new to the LCD repair and can not seem to find the Power IC on this board to test, if someone could point it out that would be great! Also, i tested all 4 backlight ports with a know good backlight i use for testing. I have included a picture of the board and the model number sticker of the monitor. any sugestions on where to go from here would be very helpfull. thanks in advance for your help!
23" HP FN747AA no Backlight (board# 715G2824-1-7)
Re: 23" HP FN747AA no Backlight (board# 715G2824-1-7)
This sounds like "2 seconds to black" from your description.
Possible causes are
1) bad caps
2) bad ccfl and/or wiring
3) bad inverter transformer
4) bad inverter sense circuitry
Since you already replaced the caps and verified the ccfls are okay, that leaves 3 and 4.
For 3, measure the resistance of the secondary inverter transformer pins for T601 and T602. Report the ohms readings. They should be within 3% of each other.--- begin sig file ---
--- end sig file --- -
Possible causes are
1) bad caps
For 3, measure the resistance of the secondary inverter transformer pins for T601 and T602. Report the ohms readings. They should be within 3% of each other.Comment
OK so i tested the 2 pins on the primary side and both transformers tested at .46 on the 20k ohm setting. is this good? i will assume so since they both tested the same. what next?Comment
edit: The secondary side are the ones "going into" the blue caps.--- begin sig file ---
--- end sig file ---Comment
If you tested just the ccfl ports, that means you didn't test the HP ccfls. Is that correct?
"2 seconds to black" could be a ccfl dying or poor ccfl wiring. See the following pictures for examples.
http://s807.photobucket.com/albums/y...klight%20lamp/--- begin sig file ---
Hmm, I just re-read this part and may have mis-intrepreted the test that you did.
http://s807.photobucket.com/albums/y...klight%20lamp/Comment
Im sorry i did test the secondary windings as you described above. there are six pins on the side closest to the 2 caps, and 2 pins closest to the 2 blue caps.Comment
I think i am going to need an "O" scope and a flyback tester to troubleshoot the rest. i figure if i am going to be repairing a bunch of these might as well. was thinking of getting one of those $80 handheld "O" scopes. i have read that they are fine for LCD monitor repair, but i do run into the occasional LCD TV. will probably go with the "blue Box" for a flyback tester. so what is the next step for this LCD? i would love to use it as my new gaming monitor as it was given to me for free......Comment
Posted a pic am i missing components in the red square? BTW this was one of those "white van" monitors......it came from a old co-worker of mine.....Last edited by houndazs; 04-08-2011, 10:31 PM.Comment
What IC are you looking at? There might be surface-mount chips on the bottom of the board.
That red-outlined section appears to be for an optional audio amp circuitry. CN601 would be the headphone jack.Comment
Thats would seem to be it, but as you have LED, and can see images, then it it should be fine, try to find the datasheet if you really want to look closer at it. Have you meaured to output of the Schottky diode, providing the inverter voltage ?Comment
no i have not....not sure which one it is, but have a good idea its the one at the top of the board on the right between the two caps correct? it has a pink component(resistor) above. am i correct?Comment
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• VCC pin (18) of PFC... -
Assuming...7 Photos -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
- Loading...
