Asus VW222U
    Re: Asus VW222U
    Here are the pics of front and back. As for fp???? i think that is fp 801. i tested it and it reads 0.7 ohms. what does fp stand for?
    The transformers both read 426 ohms on the secondary windings, with the secondary end unsoldered from the board and the 6 prong end still soldered to board.
    Circled in yellow are the areas that are discoloured, which is where the inverter transformers are. i'm guessing it is heat that causes that discolouration.
    ps thanks for the quick reply!
      Re: Asus VW222U
      Originally posted by james_69r View Post
      hey my vw222s is not got any power getting to it either... I know this thread is old but found it on google.. been helpful so far. I have checked my fuse that's fine... there is a distinctive black mark on the back of the circuit board below one of the transformers?? it is the black box looking thing with 6 prongs on one side and 2 on the other T801 T802, ive tested the 6 posts and readings go like this on both transformers... 1-2 n/a 1-3 0.3 1-4 0.3 1-5 n/a 1-6 0.3 same as the other one as well as any other combination pins 2 and 5 dont give a reading
      I tried sending some pictures through to add on here but cant seem to sort it out right now
      ive just pulled one of the transformers off and i really not sure what im looking for but the board is discolored underneath it as well....
      how did yours work out gabriel?
      The problem with my board was the main transformer solder, since I could not find any defective parts I decided to to apply new solder and doing so the main transformer 'moved' and after that the screen worked perfectly and still does.
      If I remember correctly my board also had dark brown areas that had been hot.
        Re: Asus VW222U
        FP stands for Pico Fuse.
          Re: Asus VW222U
          Picture of the back of the board is not clear enough - the brown areas look pretty normal.
          As a start just connect up the power supply and VERY CAREFULLY measure the voltage
          at the legs of the BIG Cap.- Meter on 600vdc- could be 400vDC. If you get over 300v then set meter back at 200vdc and with the black lead on a ground with the red probe
          test the pins on the socket that goes to the main board. post them along with any voltages listed for the socket on the board.
          If you smell burning again switch off and try and locate where it is from BUT do not touch the board.
            Re: Asus VW222U
            here are the readings. big cap 327vdc. Mainboard connector pins1. Jumps between 0 and -300mv 2. 4.98v 3. 4.98v 4. -0v 5. -0v 6. -0v 7. 4.98v 8. 4.98v 9. 0v 10. -185mV 11. -0v 12. 1v . i am going to replace the small ceramic capacitor that is blackened.
              Re: Asus VW222U
              Didnt mention that before? are we supposed to be able to see it?
                Re: Asus VW222U
                Sorry about that. I should have looked more closely earlier.u can't see it in the shot of the top. Hopefully replacing that cap will fix it.
                  Re: Asus VW222U
                  hi guys.
                  I was wondering if any1 can help me find out what this little thing is called?
                  I think its just a ceramic capacitor, but when i google search the numbers on it, I get no relevant returns.
                  there are 2 of these, the other 1 is burnt black. I plan to replace both
                  I'd really appreciate any help, I use this monitor loads and cant afford a new 1 right now.
                    Re: Asus VW222U
                    Ceramic cap 15J 3KV is 15Pf, 5% tolerance, 3000voltsEssential you get the same.
                      Re: Asus VW222U
                      http://www.mouser.com/ProductDetail/...b5TyMYXAsLQ%3d
                        Re: Asus VW222U
                        cheers guys, i'll try get it sorted
                          Re: Asus VW222U
                          Deses - pry it open with some plastic pry bars, pretty much the same metod for for every monitor.
                          Something like this and this.
                            Re: Asus VW222U
                            Sorry I didn't saw your reply, I wasn't expecting an answer in this thread instead of the PM.
                            I successfully opened my VW222s and I'll create a new topic asking for assistance.
                            Thanks!
                              Re: Asus VW222U
                              Hehe I tried but I was not able to PM you, good thing is that you are one step further in bringing the monitor back to life.
