LED backlit Vs CCFL Backlit
  • pavithra_uk
    • Nov 2010
    • 44
    today LED backlit monitors are major marketing trick..
    most Monitors uses only Edgelit (same as CCFL placement) hi-end units come with RGB or full array
    I start this thread for discuss LED vs CCFL.. pros, cons, life expectancy, efficiency etc..
    I like to discuss it from hardware level since most forums has information limited to picture quality & brightness.
    I found these, correct me if I wrong
    1. LED devices lack of HV inverters. they use DC-DC converter to light up LEDs.
    heat generation is minimal.
    there are no any HV breakdown, arcing or such HV related things. so it will extend life of device
    2. LEDs on/off any number of times without any problem. no warmup time.
    LEDs also has decent life time (I don't know if it proved)
    If anyone has LED monitor circuit board & LED photos.. please upload here..
  • jsog
    • Feb 2011
    • 220
    Re: LED backlit Vs CCFL Backlit
    LEDs are solid state and (I think) they don't color-shift with age.
    Never had an LED-lit monitor apart, although I did save the LED strip from a broken laptop screen. Do they use DC-DC converters, or just 12V or 24V direct?
    • pavithra_uk
      • Nov 2010
      • 44
      I think they use DC-DC converter with current limiting.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        i've got a LED strip out of a cracked 15.6" laptop display here.
        odd thing is that it plugs directly into the tcon board instead of some other (DC/DC converter) board.
        the flexcable has 10pins, 3 of which are tied together (GND?) and one is unused. so i assume 1 GND and 6 positive pins.
        another thing about LEDs is that they don't just stop working like CCFLs.
        the rated lifetime in the datasheets usually means the lifetime from 100% light output down to 50%.
        they'll still work after that.. just not as bright..
        edit: plus, if you don't run them at max. brightness all the time, they'll probably last longer than the rated lifetime anyways..
        • turbozutek
          • Jan 2009
          • 71
          LED monitors are GREAT if you want to see your own reflection in everything you are looking at. I want some decent (and cheap) options for MATT screens, even if the blacks are a little less vivid.
          • mockingbird
            • Dec 2008
            • 5484
            You're saying it's impossible to make a matte LED-lit LCD?
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              No... just that most happen to be glossy.
              A working TV? How boring!
              • retiredcaps
                • Apr 2010
                • 9271
                I finally found the thread. See
                https://www.badcaps.net/forum/showthread.php?t=13365
                It would have been the 1st repair here, but the OP sent it back for warranty.
                --- begin sig file ---
                --- end sig file ---
                • turbozutek
                  • Jan 2009
                  • 71
                  No, IF you can find one in the first place, you'll probably notice it's three or four times the price of the 'mirror style' glossy.
                  Currently I'm hunting out a new laptop to replace my old Dell and here's a complete list of every modern laptop I've found in my price range that has a matt screen:
                  1.
                  Yeah, none. There's no technical reason for it to be this way, but it is.
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    what's your price range and the specs you're looking for?
                    i've found a price comparison website which has a filter for matte/glossy, but it's in german.. so just giving you the link probably won't help lol
                    as for the matte LED monitors.. you could still build your own out of a CCFL one :P
                    the only tricky part would be the interface with the LCD controller board (for dimming the backlight and turning it off etc.)
                    • japlytic
                      • Oct 2005
                      • 2086
                      Before LED TVs came out (with LED backlighting), there were portable DVD players with LED backlighting.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        And mobile phones. And the PSP. And so on.
                        • ttmi100x
                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                          by ttmi100x
                          Greetings everyone,
                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                          Upon closer inspection...
                          07-31-2024, 06:36 PM
                        • Pipolups
                          Corsair K70 LUX RGB dying LEDs
                          by Pipolups
                          Hi there !
                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                          10-08-2024, 11:58 AM
                        • jaroslav.psenicka
                          Apple MBP A1398 EMC 2881 No backlit, PP3_G3H drops to 10.8V after start, 0V on LVDS pin 1
                          by jaroslav.psenicka
                          I have a MBP A1398 EMC 2881 here, it chimes, boots and shows picture on external screen
                          there is an apple logo on the display, no backlit
                          I measured the PP3_G3H on the backlit fuse - it's 12.6V when not powered and it drops to 10.8V after startup.
                          Is this OK?
                          Also measured the LVDS connector pin 1, there is 0V, could that be the backlit driver chip?
                          Also checked all 4 "backlit" capacitors, all OK, not shorted.
                          Thank you very much,
                          -jp
                          12-02-2024, 01:29 PM
                        • mikey5791
                          Help on Samsung Syncmaster T220 dead ccfl lamp
                          by mikey5791
                          This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                          Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                          10-18-2020, 03:17 AM
                        • THE GTC
                          Insignia NS-37D20SNA14 intermittent LEDs
                          by THE GTC
                          So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                          When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                          11-03-2020, 02:40 AM
