Viewsonic VA912b brightness no response
  • spintop
    • Feb 2011
    • 132
    I am not sure if this is hardware related to the CCFL inverter or software.
    Issue: The screen brightness has no response when the button is pressed. However, can see that the OSD brightness scale is moving up/down from 0-100. Contrast control is working fine, and everything else is fine.
    Attached the power supply photo.
    (U1- MP1038EY)
    Advice needed. Thanks.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Viewsonic VA912b brightness no response
    (U1- MP1038EY)
    First, give yourself a big pat on the back. The pictures were good, and the datasheet for the inverter controller was a big help.
    On the top view of the power supply / inverter the bottom two leads are for the inverter on/off control and the brightness. The brightness signal goes to either pin 11 or 12 of the MP1038EY, probably pin 12.
    I'd measure the voltage on the two pins, the On/Off should be about 3.3V with the backlights on; the brightness should be between 0 and 1.2 volts, and vary as you adjust the brightness from the menu. If the brightness voltage doesn't vary, look at the signal card. If the brightness does vary, look at pin 12 of the MP1038EY; there is some circuitry between the connector and the IC.
    PlainBill
    • spintop
      • Feb 2011
      • 132
      PlainBill
      Thanks PlainBill for the advice.
      Measured brightness voltage not varying when adjustment from the OSD. Looks like issue is in the logic board. Without schematice diagram, will be hard to troubleshoot. I think i can live without brightness adjustment for now.
      attached is the logic board area around the connector.
      • PlainBill
        • Feb 2009
        • 7034
        In this case, Q3 and Q4 would be suspects. One drives the inverter On / Off line, the other is the D-A converter.
        PlainBill
        • Scenic
          o.O
          • Sep 2007
          • 2642
          only thing left to check would be the 2 tiny transistors and maybe the voltage regulators (bottom left corner)
          one of them (the lower one) seems to be adjustable, as there's no -33 or -18 marking for 3.3V or 1.8V..
          can't tell what's written on the upper one though..
          edit: i've seen a cheapo monitor once which used an adjustable v-reg for the brightness control signal..
          • spintop
            • Feb 2011
            • 132
            Thanks alot guys for the advice. Found the faulty component and resolved the brightness issue.
            With PlainBill & Scenic advice, focused on Logic board. Initially tried swapping the transistor (Q4) next to the connector with the transistor controlling volume control, as i found out they are using the same transistor.
            Doesn't solve the problem, so eliminated the idea of faulty transistor.
            Found out that the adjus signal is always 0V. Swapped out C13 next to the leg of the connnector, and it worked !!! A faulty 1uF ceramic capacitor, grounding the adjus signal to gnd.
            Once again thanks guys !!!
            • PlainBill
              • Feb 2009
              • 7034
              Good job. We've had a number of people report problems due to a shorted ceramic cap.
              PlainBill
              • dr.thodt
                HP Pavilion 15-1812nd scrren brightness issues
                by dr.thodt
                I have a notebook, HP Pavilion 15-1812ND with brichtness issues.
                When in windows, I use the the brightness keys on the keyboard, brightness goes up aprox (75%) then the screen begins to flicker and gets darker again.
                When I lower the brightness again it's getting brighter first and then it dims and the flickerings gets less.
                I already chaned the screen and LVDS Cable.
                Does anyone ever seen this problem and maybe have an idea how to fix this.
                Any help would be apprecited.
                Thank you
                09-24-2024, 04:15 AM
              • lostone
                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                by lostone
                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                05-19-2024, 11:40 AM
              • cloudy
                HELP - Contrast/brightness issue with subtitles on screen
                by cloudy
                Hi everybody
                Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
                Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
                Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
                It occours both on ubuntu and windows...
                01-01-2023, 05:12 PM
              • sarto
                GETAC S410 G1 brightness problem
                by sarto
                Hi everybody. I have a Getac S410 G1 with a screen brightness witch cannot be adjusted. It is at full brightness when the charger is plugged in (19V on the LCD connector) and at minimum under battery (12V on the LCD connector). Does anyone know where the problem is coming from ? Thank you.
                03-08-2025, 04:30 AM
              • fixxy88
                Panasonic 55DX600u second fault - panel brightness pulsing on right side
                by fixxy88
                After getting the backlights up and running a second fault has emerged on this TV. I was going accept defeat and move on but thought I'd have a quick look at it in case it was something simple. The right side of the display exhibits a panel brightness (not backlight brightness) pulse every 2-3 seconds in a stable timing.
                I poked about on the TCON test points and found one voltage that is fluctuating in the same pattern. VGH-ODD (Pin 47 of U10) is sitting at ~-6.5v then goes up to ~28v when the brightness pulses then goes back down to ~-6.5v again in a repeating pattern.
                03-22-2023, 02:58 AM
