Should I worry about dark/burnt? spots on power board?
  • bw1
    • Sep 2010
    • 172
    A 19" Soyo monitor came in today - won't power up. A couple of obvious caps are bad (don't have these particular values in stock right now, otherwise I'd probably just try them) but I'm wondering about what looks like heat damage on the board.
    Is this normal? I've seen it before, but not sure if this is just something that happens, or if I should question attempting a repair on this one. For the record, nothing else in the chassis or anything else under the hood had any sign of heat damage, if that's what this is.
    Pictures attached. Comments appreciated!
  • sabre504
    • May 2010
    • 449
    • United Kingdom
    Re: Should I worry about dark/burnt? spots on power board?
    Hi post a pic of the back of the board
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      Once all four of those caps are changed, you should just power it up to see what happens. I wouldnt worry about the burn marks until that is done first. If it doesnt power up after the cap change then i'd look further.
      • bw1
        • Sep 2010
        • 172
        Thanks Dgtech, I was hoping to hear that response. If I had these caps in stock I would have just done it, but since it involves ordering, ordering extra to have more in stock, and waiting for arrival, I was just making sure it was worth it.
        I'll try to get a pic of the back of the board shortly if I can track down another camera. For all of the computer/tech stuff laying all over here, it's one of the hardest things to find when I need it.
        • jetadm123
          • 2169
          I'm almost willing to bet those scorch marks are caused by SMD mosfets on the underside of the board. Also, make sure you replace ALL 5 of the caps, not just the bloated ones.
          • bw1
            • Sep 2010
            • 172
            Here is a pic of the back side.
            • jetadm123
              • 2169
              Nice photo! Yeah, it looks like the marks are caused by mosfets Q9 and Q10. If you looked up the data sheets, you'd see that they pass a lot of current, which is why they run hot.
              • bw1
                • Sep 2010
                • 172
                I'll replace the caps and check back here and post results. Thanks!
                • bw1
                  • Sep 2010
                  • 172
                  Everything looks good - replaced all 5. I'll ignore the dark spots... unless there are more problems, anyway.
                  Thanks for the advice!
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
