ViewSonic VX2235WM goes blank after 3seconds turn on.
  • supremacy13
    • Feb 2011
    • 25
    I have ViewSonic VX2235WM, I turn it on and I can see on display. By time when it pass about 2-3seconds...display goes blank, I turn it off and turn it on again, I can see windows logo then it goes blank again.
    I had replaced 5 caps already, still same problem.Any idea I should be able to fix or what?
    thanks
  • PlainBill
    • Feb 2009
    • 7034
    Re: ViewSonic VX2235WM goes blank after 3seconds turn on.
    Classic two seconds to black.
    Classic questions. Caused by Caps, CCFLs, Transformers, other in that order.
    Which capacitors did you replace?
    Why didn't you replace all of them?
    What capacitors (brand and series) did you use for replacements?
    When will you supply pictures?
    PlainBill
    • hasel17
      CH341a can erase and read but can't write and blank check
      by hasel17
      So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
      Code:
      Checking for blank...
      (Press
      10-26-2023, 06:20 AM
    • lostone
      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
      by lostone
      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
      05-19-2024, 11:40 AM
    • RetroComputingGrotto
      Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
      by RetroComputingGrotto
      I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
      I've uploaded a video of it happening on YouTube:
      I've taken the monitor...
      01-11-2024, 05:37 AM
    • Chrissygizmo
      Panasonic TX-48CX350B backlights but white screen , blank screen
      by Chrissygizmo
      Hi all, I’ve got a problem I hope someone can help me fixi.
      I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
      01-11-2025, 03:18 PM
    • Spoonicks
      ASUS VH238T blank screen with backlight
      by Spoonicks
      I am having a problem with a ASUS VH238T.
      The monitor started by just going blank, but the integrated speakers, and the backlight worked. The OSD didn't pop up, neither did the messages of DVI No Signal, nor the Asus logo.
      Turning off the monitor, and turning it back on made no difference. But leaving the monitor off for a few hours returned the monitor back to normal. The problem will eventually return after a couple of hours.
      Today, it started exhibiting another symptom: the display started showing a white image, that didn't take the whole screen....
      07-04-2023, 01:29 PM
