Samsung 226BW No Picture
  • pedro042
    • Feb 2011
    Hey Guys, I have a Samsung 226BW that has no sign of life except that the power light flashes about once every 5 secs. The monitor doesn't respond to any of the buttons. All the caps on the IP baord have been replaced. The 13.5v output to the logic board is measuring 15.7v. Measuring the testpoint voltages on the logic board I've found the following:
    1.8v = 1.8v
    3.3v = 3.3v
    5v = 0v
    14v = 15.7v
    There is 5v (5.42v) present on the output of IC702 (DC-DC convertor).
    Unfortunately I can't locate a schematic, for the particular board, to be able to find where the 5v goes missing.
    I've search the forums and cannot find a solution to this particular issue.
    I have the same boards as shown in this message:
    https://www.badcaps.net/forum/showpo...5&postcount=10
    Thanks,
    Dave
  • alexanna
    • Mar 2010
    • 1346
    Re: Samsung 226BW No Picture
    Do any of the voltages change with the logic board disconected?
    • Rtech
      • Jul 2010
      • 1095
      Flashing Power lamp,indicates a problem in the Inverter circuit,eg shorted transistor etc,particularly as you have changed all the caps.
      • pedro042
        • Feb 2011
        Thanks very much for the quick reply guys.
        No change in voltage when the logic board is disconnected.
        I'll give them a look tomorrow. Any ideas what voltages I should be "seeing" on the Schottky Rectifier?
        Thanks,
        Dave
        • alexanna
          • Mar 2010
          • 1346
          These boards are huge problem for me getting solder to melt enough to remove the capacitors, and getting the new caps soldered back in has also caused me some problems.
          Suggest you inspect your soldering very closely, gently rock the caps you have installed and watch for any movement on the solder pads.
            09-07-2024, 05:50 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • ohren
            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
            by ohren
            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
            The models launched in 2018 and 2019 respectively....
            09-08-2023, 05:24 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
