Create a "How to post a problem" sticky?
This topic is closed.
+ More Options
Posts
  • Ritalin
    • Sep 2010
    • 194
    Hello all you fellow repair-junkies!
    So as I've been look through all the current threads I noticed a majority of them you see the same thing. "Please post pictures using our forum and post them as attachments", check for this, check for that, etc.... I myself was guilty of doing this my first post. So I was thinking maybe we should have a sticky with "How to post a problem" and also have a quick "If you're experiencing this, check this" guide.
    I have a few LCDs around that have different symptoms and would be willing to take pictures, but I don't quite have the technical background to say what it could be and what to check.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Create a "How to post a problem" sticky?
    While the thought is good, there are several issues. The major one is "How do we get someone to read the sticky before posting?" And even then, some people don't believe in following suggestions, even when very good reasons are explained.
    As far as the problem monitors you have, I'm sure you know enough to include a concise description of the problem. With that, the pictures, and an explanation of what you have already tried, it is easy to come up with the next steps.
    I'm not sure it would be effective creating a troubleshooting tree. They assume a significant technical background. It is easy to say 'Check input fuse', but by the time you cover all possible configurations the thread would be rather long.
    PlainBill
    • retiredcaps
      • Apr 2010
      • 9271
      Here is a recent post that I think provides excellent info for a post #1
      https://www.badcaps.net/forum/showthread.php?t=13258
      --- begin sig file ---
      --- end sig file ---
      • Ritalin
        • Sep 2010
        • 194
        PlainBill
        Ya, I see your point Bill, I just wish there was a way to organize the information and have to somewhere to reference to. Like for me, I have 4-5 LCD monitors laying here that I don't know what to do next, and I don't want to plague the forum with threads for each one. So maybe I'll just have to write up my own and keep it for myself.
        @retiredcaps: That is an excellent first post and it would be nice to have everyone follow that format, but like Bill said, not everyone reads stickies or will take the time.
        • jetadm123
          • 2169
          Nothing wrong with starting a new thread for a monitor. One thread I recently saw was for a Dell E172? monitor, which ran 23 pages! Too much! Just provide good photos and a clear description of the problem. You've probably read enough threads where you pretty much know what info is required to give you the fastest, most accurate response.
          • EGuevarae
            • Nov 2008
            • 1336
            I agree.That is kind of confusing.But it is worse when Thread refers to Monitor "A" and then someone jumps in and says "I have monitor B with the same problem and ...."....that's where the issue starts to get hairy ....
            There are 10 kind of people in this world: those that understand binary, and those who don't.
            • ASUS ROG Maximus IX Code
            • Intel Core i5-7600K 3.8GHz
            • 16gb GSKILL TridentZ RGB DDR4-3200
            • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
            • Windows 10 Pro x64
            • GeForce GT1050
              2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
            • Gambler057
              • Aug 2023
              • Perú
              Hello
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • perzyk23
                Lenovo T580 - LCD Panel problem - error 0288
                by perzyk23
                Good morning,
                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                10-25-2024, 12:42 AM
              • SDNarcia
                Dell 15R-5521 keyboard problem (KBC?)
                by SDNarcia
                Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                As additional information,...
                07-20-2024, 10:47 PM
