Dell 2007FPb No Power, Power and 1 icon (VGA) blinking
  • tboxxx
    • Feb 2011
    • 21
    #41
    Re: Dell 2007FPb No Power, Power and 1 icon (VGA) blinking
    Another one is TEK DMM850, but it did not help a lot.
    The readings are not stable and not even close to a nominal.
    • retiredcaps
      • Apr 2010
      • 9271
      #42
      Okay, let's see if I put these puzzle together properly?
      1) On pin 3 of J033, see if there is continuity to each negative part of FD 7/8 (the white stripe).
      That is, put your multimeter on ohms. See if the ohms measurement is less than 1.0 ohms from pin 3 (yellow) of the voltage regulator to each diode (yellow again).
      2) If yes, then I suspect the diodes could be bad. You will have to desolder both FD 7/8 and retest them out of circuit. If they test good, then I suspect the voltage regulator could be bad.
      --- begin sig file ---
      --- end sig file ---
      • tboxxx
        • Feb 2011
        • 21
        #43
        I am reading 0.1 ohms with TEK and Meterman. Meterman beeps on continuity test.
        I will desolder both FD and check those.
        • chad720
          • Jan 2011
          • 16
          #44
          Hi there, I had the exact same simptoms as tboxxx, so I donยดt think if I should open a new post. No response of the panel buttons, vga keeps blinking and only 19V on the conectors.
          1) I had found on the USB board a J598 voltage regulator faulty (in short) as the s4 64A diodes that corresponds to this part of the circuit. Also the 3A fuse was blown and the zener ZD701 was shorted (thanks to billy66 that has made a good effort to discover for me the breackdown voltage).
          2) I replaced everything, but the vga card has also a short, that I cannot isolate. Iยดve removed all the caps that was on the shorted trail, hoping one was shorted but with no luck, if tboxxx allow me to use his pictures,
          In red are the shorts (except the 3A fuse that was open). On the vga, afther replacing the big 950T (1,8V 1A regulator) I realiced the regulator wasnยดt shorted. The other fet of the circuit wasnยดt shorted either. (if someone knows a replacement just in case the nยบ is T044 / 950t65 the slash means new line)
          On blue are something remarkable about what seems to be an eprom, that has 4 pins for ground (not corresponding to datasheet).
          thatยดs all for now, if someone could please tell me what can I test, as I havent found datasheet for the FLI5961 nor the TW9606, and Iยดm running out of hopes here.
          More to tell is that not a single zener of the vga card was shorted (on both ways), and the 5 pin stuff on the back of the vga says 69789 or 697B9 (canยดt find datasheet or replacement but I think the short shouldnยดt be there as both pads are linked with a cap that I removed and was ok).
          Thanks for reading and any advice would be really apreciated!
          Chad
          PW: to tboxxx: your board seems to have a white residue, make me wonder if it has get wet or something.
          • a69
            • May 2011
            #45
            Hi all.
            Need a circuit on the monitor DELL 2007
            • Badgen
              • May 2011
              #46
              Hello everyone.
              I need to know breackdown voltage of ZD701.
              Can anyone help me, thanks
              • dnyaj
                Can anyone help me? I pickup a dell 2007FPb and the problem is that the LCD wont stay on. It keep on shutting off and turn itself back on without me hitting the power button. Sometime it stay on for a few minutes. I had re-solder the connection for the power and all the caps but still won't stay on. Let me know if anyone have a solution or what to test.
                • kasatmata
                  • Sep 2012
                  • 18
                  • Indonesia
                  #48
                  thanks
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
                    05-29-2024, 02:01 PM
                  • noipi
                    DELL INSIPRON 14 No power blinking orange/white
                    by noipi
                    i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
                    05-06-2025, 08:08 PM
                  • Mark01
                    Dell Optiplex 7490 AIO - red power led after flash
                    by Mark01
                    Hi guys,
                    This is my first post! ๐Ÿš€
                    I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
                    Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                    07-04-2025, 12:54 PM
                  • zlr8r
                    Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                    by zlr8r
                    hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                    Ill try and give as much info as I can.
                    Dell Inspiron 17 (7786) Laptop
                    Service Tag: 5J0NHT2
                    Bios: 1.9.0
                    When I received this , it would only flicker on the KB backlight for a second, then off and on.
                    Then it started getting weirder!
                    Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                    12-12-2023, 09:31 PM
