Replaced bulging caps, and pop... nothing
  • Karstedt
    replied
    Re: Replaced bulging caps, and pop... nothing
    Thanks for the help guys, but that power switch proved a bit much for my amateur skills and underpowered iron. I mucked up a few solder pads when removing it, so I'm not really expecting it work when I patch it up.
  • Rtech
    replied
    That does not surprise me one little bit.
  • alexanna
    replied
    Originally posted by Rtech
    Used by some Acers,some Viewsonics and Hanns G HX191.....plus no doubt many others.
    I have a Va912 here i just took apart but guess what---- has a delta board
  • Rtech
    replied
  • alexanna
    replied
    https://www.badcaps.net/forum/showth...highlight=acer
    looks like this acer uses the same p/s
    wonder if samson still has to help identify parts?
    Don't miss Rtechs post above
  • Rtech
    replied
    Data Sheet for the part is as follows:-
    http://pdf1.alldatasheet.com/datashe...FSDM0565R.html
  • Scenic
    replied
    looks more like it has blown apart
    your only chance would be to find the missing chunk with the part number on it..
  • jetadm123
    replied
    Originally posted by Karstedt
    The fuse is definitely blown. But I don't know about what I'm assuming is the switching transistor you're talking about. It's definitely funny looking, but I don't know what it's supposed to look like. I can't read it either, so I don't what to replace it with.
    IIRC, I believe that is a plastic cover. If you remove the screw, it should come off and expose the mosfet underneath.
  • Karstedt
    replied
  • Rtech
    replied
    Thanks,I know what Mosfets etc are, as I am electronics qualified,but you are the only one I have ever seen use the term on here,or anywhere else. You learn every day ....eh
  • Trinite
    replied
    Having worked with all sorts of electronics over many years...have never heard the term 'switcher' before.Terminology for many subjects can have different names for different things...so define 'switcher' in English please ???
    The term "switcher" is short for "switching transistor". Essentially, it is a high power transistor (generally a MOSFET type, but also can be bi-polar) that is used in combination with a PWM (pulse-width modulation) circuit.
  • Rtech
    replied
  • Trinite
    replied
    That switcher MOSFET looks a bit fishy to me. If you can get a close look at it, check for any pitting, cracks or discoloration. Also check the fuses (anything labeled with an "f" on the PCB) for continuity. An open fuse will indicate that it is more likely a silicon failure than a capacitor failure.
  • mastertheknife
    replied
    Also check this fuse, the live wire goes through this fuse before anything else.
    Its probably blown, but without finding out the cause, it will probably blow again.
    mastertheknife.
  • Karstedt
    replied
    Originally posted by yyonline
    I am not familiar with the "NTE" capacitors you used as replacements. What are their specs and how do they compare to the originals?
    They are higher voltage with the same uF as the originals. I don't know the other specs, and haven't used them before either. They were available at the local electronics parts store, and they use them for repairing LCD's...
    Originally posted by retiredcaps
    If you have no power and no power LED, then check the bridge rectifier (BD101) for shorts. Number the pins 1-4 and put your multimeter on 200 ohms.
    With power off and lcd unplugged, measure pins 1-2, 1-3, 1-4, 2-3, 2-4, 3-4. Any reading under 30ohms suggests that the bridge rectifier may be shorted.
    You are correct, no power, no LED. I'll check that this weekend. Thanks.
  • retiredcaps
    replied
  • yyonline
    replied
    I'd expect that area of a power supply to use low ESR caps. I am not familiar with the "NTE" capacitors you used as replacements. What are their specs and how do they compare to the originals? They're not a brand I've heard of before, so I'm unsure of their long term reliability.
  • Ritalin
    replied
    Ya, I agree with replacing the others as well. Usually when they are in a cluster like that, they all get affected. You could take off the other ones and test them with a meter if you have one. Also check the bottoms of them for bulging, for some reason some brands tend to go bottom first then bulge at the top if it's that bad.
  • Karstedt
    replied
    Originally posted by Trinite
    Show us a picture of the switchers and the diodes. Those are the other things that tend to go "pop". Also a complete pic of the underside of the board would help too, as there are a lot of SMD components on that side.
    Well, I can post some different angles and a complete underside. But I can't really get a much closer pic of anything... they get way out of focus.
    Did you install one of the caps backwards?
    Definitely not.
  • retiredcaps
    replied
    I heard a pop (not an exploding cap) and nothing happened.
    Generally, when you see 3 bad caps, you might want to replace them all.
    by momaka
    03-15-2023, 10:17 PM
  • zlr8r
    HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
    by zlr8r
    Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
    To begin with, this laptop was dead-dead.
    Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
    • am getting white power led
    • 5-long-flashes on CAPS Lock and NUM lock
    • then, fan full speed
    • CPU heats up some (smaller die PCH, does not)
    • always constant black screen no matter what's tried
    • no USB recognition
    • no HDMI output
    this is as far as I can get with it and not sure where to inspect next ?
    I tried...
    03-27-2024, 03:13 PM
  • cmlewis89
    LG 47LB5DF blown power supply board
    by cmlewis89
    Hi folks,
    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
    09-03-2024, 07:50 PM
  • bcstedt
    LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
    by bcstedt
    LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
    Problem:
    On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
    It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
    01-18-2024, 01:03 PM
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
