Sony SDM-HS73 on for 2 seconds then off
  • retiredcaps
    • Apr 2010
    • 9271
    #41
    Re: Sony SDM-HS73 on for 2 seconds then off
    Originally posted by Freezer
    This will be the 3rd monitor I've worked on, so I have some experience.
    [*]If all else fails I may consider CCFL replacement.
    If you already have 2 working monitors, you can stretch the ccfl cable from the Sony to one of the working ones as a test.
    --- begin sig file ---
    --- end sig file ---
    • Freezer
      • Jun 2010
      • 124
      #42
      Using the schematic in this thread I tested the 4 mosfets as suggested. All 4 check out okay. None of them indicate a short, and all 4 have very similar readings. I'm in the process of more thoroughly testing the inverters, I'll report back with those number soon.
      I just acquired a broken Viewsonic Q191wb (19" widescreen) off craigslist. Can I use this monitor to test the CCFLs in the Sony and vise versa? I'm not sure since the Sony is a 17" and the Viewsonic is a 19". Also, I'm not sure if the different makes would cause a problem.
      So in addition to my posts on the Sony SDM-HS73, I'll be posting soon in the existing thread for Q191wb.
      • PlainBill
        • Feb 2009
        • 7034
        You can try using the CCFLs in one to test the other. Of course, if the CCFLs in both are bad....
        PlainBill
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          Members report that a couple of inches difference doesn't make matter for this test. If the difference was more like 4 or 5 inches, it may make a difference.
          • Freezer
            • Jun 2010
            • 124
            #45
            I replaced the 4 27K3KV ceramic disc capacitors but that didn't fix the problem. I am beginning to suspect one of the inverters is bad. Between several of the pins the resistance starts at 6+ mohm and then after about 1 second it drops to several hundred kohms. This only happens on one transformer, but consistently happens between a certain group of pins. So I'm thinking either the transformer is bad, but I guess it's possible a short in the board is causing this as well. My plan is to try and desolder the transformers and test them out of circuit. Should be interesting, I've never tried to desolder something with so many pins.
            • Freezer
              • Jun 2010
              • 124
              #46
              I did want to make one final post on this monitor. I never did fix this monitor, instead I decided to use the monitor as a learning experience. I completely disassembled the panel. I was curious to see the make up of the inside of the panel. That way, if in the future I have a monitor that needs CCFL replacing I know what to expect. All and all this was a fun project, I'm just a little bummed I wasn't able to fix it.
              Even though I wasn't able to fix it, I *believe* I found the problem. The upper inverter would briefly produce an electric noise almost like it was arcing. Also, I was getting some very inconsistent resistance readings from the inverter. So I suspect this inverter went bad.
              While working on this monitor there were a few things which struck me.
              1. The build quality on this monitor was higher than that of many other monitors. The frame contained more metal and less plastic than you would typically find. Probably my favorite feature was the fact the monitor was assembled using screws instead of plastic tabs - this made it easy to disassemble.
              2. The internal components were nicer than I was expecting. I recently got an ESR meter and I went back and retested all the caps in this monitor. They all tested good. I also noticed the caps were high quality caps to begin with. After working on so many cheap monitors like Samsung and ViewSonic it's nice to see one with decent components for once.
              I guess both of these are to be expected when you spend a little more for a nicer brand like Sony versus the el-cheapo brands.
              • jetadm123
                • 2169
                #47
                Yes, it is too bad that you couldn't repair it. I've seen several sony monitors on this site with problems similar to yours that also went unfixed. Hopefully, someone will find some common part that has failed on these models. Although, it would seem that you've come close with a possible failed inverter transformer. Hopefully, you can find a replacement transformer to prove your theory.
                • mauda
                  Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                  by mauda
                  I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                  Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                  05-21-2023, 11:56 PM
                • tec3000
                  Sony LED 65X9005A shuts down after few seconds - looking for help
                  by tec3000
                  Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                  I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                  03-20-2024, 07:29 AM
                • electomech-fixer
                  First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                  by electomech-fixer
                  I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                  I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                  09-15-2025, 01:42 AM
                • Carlos#2003%
                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                  by Carlos#2003%
                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                  02-15-2024, 07:52 PM
                • ravi_1617
                  Sony MBX-223 ,M971 , Shutdown after 40 seconds
                  by ravi_1617
                  Hi.! This Sony board turns off after 40-42 seconds.
                  (with adaptor/battery or both)
                  Don't turn on until 20 seconds,
                  If I disconnect Power immediately when off,than I can turn on, than again stays on same time, aprox 40 seconds
                  Did changed ,
                  thermal paste, CPU.
                  Flashed bios also.
                  fan heatsink also clean
                  Before turning off fan also turns on.
                  Any points I am missing
                  08-31-2021, 11:42 PM
