1800FP Green light on but no image on screen
  • Welchs101
    • Sep 2008
    • 979
    Re: 1800FP Green light on but no image on screen
    Another update.
    I took the logic board out of the "bad" monitor and put it into my working monitor. No surprise, my working monitor with the "bad" logic board in it did not work.
    So its definite.....the logic board is the problem.
    Now, i need to figure out if its worth fixing.........any ideas?
    • jetadm123
      • 2169
      Originally posted by Welchs101
      Another update.
      You can try the fix the severach used on the link below, post #12:
      https://www.badcaps.net/forum/showth...0fp+logic+card
      It involves replacing two 10uf caps, C739 and C207. You can use regular electrolytic caps as replacements.
      Eventhough your logic card is an earlier model, it might be worth a try. Just be careful when you unsolder the original surface mount caps off the board. There are two tabs, one on each side of the cap. Heat each tab and lift gently. You may have to use a rocking motion, but gently as you dont want to lift the solder pads off the board.
      • Welchs101
        • Sep 2008
        • 979
        do you think i need to replace those two or could i just solder two in parallel with those two 10uf caps, C739 and C207?
        • jetadm123
          • 2169
          Replace. Putting another cap in parallel will only increase the capacitance.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            But it will decrease the ESR too. If the originals aren't shorted, yes you can try just soldering them in parallel.
            A working TV? How boring!
            • Welchs101
              • Sep 2008
              • 979
              ok. I removed after much effort the two surface mount capacitors (C207 and C739). I replaced them with electrolytic 10uF/50V caps.
              Still did not work.
              Anyone have any other ideas? I feel like i am shooting in the dark on this one.
              • steve2
                • 121
                #27
                I have looked at this some. Your pic readings shows pin 7 (R as you marked it) as having 5vdc on the bad monitor and 0 on the good. Pin 7 of J702 is the dim adj signal. Page 33 of manual. Does that vary when you dim it, or can you dim it?
                • Welchs101
                  • Sep 2008
                  • 979
                  steve,
                  i am not sure how to dim it given that i can not see an image on the screen. To dim it i would need to hit the menu button and then dim it ........right?
                  thanks for looking at this....i really appreciate it.
                  • jetadm123
                    • 2169
                    #29
                    Interesting observation by steve2. After you've rotated the schematic counterclockwise on page 29 , on the lower right side of the service manual, you will notice that cap C207 (the one you replaced) is part of the dimming adj circuit. Maybe you can check the other components of the dimming circuit for shorts, etc.
                    • Welchs101
                      • Sep 2008
                      • 979
                      i will give that a look. Page 29?
                      • Welchs101
                        • Sep 2008
                        • 979
                        where do you see C207? i dont see it?
                        • jetadm123
                          • 2169
                          #32
                          Apparently, there's multiple versions of the service guide. The one I'm referencing is the 1800FP CL-42 located here:
                          • steve2
                            • 121
                            #33
                            That looks like the correct service manual. The one I posted didn't have the C207 and C739 as electrolytics. The reason I looked at this part of circuit is pin 7 of J702 reads 5vdc on bad monitor and 0 on good monitor. My first instinct was a transistor not turning on, but couldn't find it on my manual. Your manual shows Q201 right there in the dimming circuit. The 5 volts is going right thru r206 and r205 to pin 7 of J702. The transistor could be bad or the base is not getting turned on.
                            • Welchs101
                              • Sep 2008
                              • 979
                              I followed the link you sent for the manual...........i cant seem to download it. Is it possible you can post just the pdf file?
                              • steve2
                                • 121
                                #35
                                I had the same problem downloading it. Then I put the model # in the search box and when it came back up, it had a download button, which then worked. I tried to post the pdf manual here, but it failed twice in a row. It is less than 3 mb and themax allowed is 9mb, so I can email it to you if you want or can't get it to download.
                                • Welchs101
                                  • Sep 2008
                                  • 979
                                  steve,
                                  i emailed you with my email address. Please do send it to me if you can.
                                  • steve2
                                    • 121
                                    #37
                                    I sent it a few hours ago. I just re-sent now at 2.35 The first one may be in your spam/junk folder. Let me know if you get this one.
                                    • Welchs101
                                      • Sep 2008
                                      • 979
                                      i checked the bjt that was near the C207.......it looks fine. I also compared the reading i measured for the bjt to the reading i measured on the "good" monitor and they were the same.
                                      • Welchs101
                                        • Sep 2008
                                        • 979
                                        Just a thought.......if the EEPROM were "bad" ...........would this cause the problem?
                                        How to check the eeprom?
                                        • nadeem
                                          • Feb 2011
                                          #40
                                          thx sir i am very thank full to all of u
                                          • 3D Modelka
                                            AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
                                            by 3D Modelka
                                            Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
                                            02-09-2024, 02:42 AM
                                          • matthewmcconaughey
                                            I need help with my friend Sony GDM-FW900 24” CRT
                                            by matthewmcconaughey
                                            Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                                            I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                                            1. It started with a bright and greenish picture upon starting a cold monitor.
                                            2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                                            05-16-2023, 03:15 PM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light but no audio
                                            by MOSSEP
                                            Hi
                                            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                            I have already tried replacing all of the...
                                            01-26-2025, 08:18 AM
                                          • String2016
                                            samsung np300e green screen
                                            by String2016
                                            I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
                                            07-26-2025, 04:00 AM
