Dell 1905FP Won't Turn On
+ More Options
Posts
  • retiredcaps
    • Apr 2010
    • 9271
    #41
    Re: Dell 1905FP Won't Turn On
    Originally posted by ryszardx
    Is there a value for on board testing - i.e. resistance unpowered in primary and secondary?
    Primaries should be 0.3 ohms. Secondaries will range from 250 to 1500 ohms depending on the transformer. Post your results and we can help interpret.
    --- begin sig file ---
    --- end sig file ---
    • alexanna
      • Mar 2010
      • 1346
      #42
      . Did you connect a full set of CCFLS?. If so, were they all the same brightness?
      I'm now suspecting a bad (arcing) transformer.
      PlainBill
      Have you tried what PlainBill sugested?
      If you don't have a ring tester you may be able to prove the coil as being a problem, by looking for a difference in the brightness of the flash of the backligts, on each individual transformer.
      • ryszardx
        • Feb 2011
        • 20
        #43
        PlainBill I connected a full set they didn't stay on long enough but at what I could see they were equally bright
        • ryszardx
          • Feb 2011
          • 20
          #44
          both transformers had the same results:
          @.5 ohms at the primary and @450 ohms at the secondary.
          • alexanna
            • Mar 2010
            • 1346
            #45
            Reading through other 1905 FP threads; one had an issue of bad solder joint at the back light on pin.
            Can you see if the BL on voltage stays the same when the lamps turn off?
            • retiredcaps
              • Apr 2010
              • 9271
              #46
              These readings suggest that the inverter transformer is likely good. However, I should point out that this test is not 100% accurate for reasons described by PlainBill at
              https://www.badcaps.net/forum/showpo...39&postcount=9
              • ryszardx
                • Feb 2011
                • 20
                #47
                Excellent breakdown on inverter transformers!
                I noticed no one mentioned the 2 transistors in the inverter circuit. Are they discounted for whatever reason.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #48
                  This thread is long overdue for some pictures. Please attach clear focused pictures of all your boards using the manage attachments feature. Please do not post inline.
                  Then we can see the 2 transistors in question.
                  • ryszardx
                    • Feb 2011
                    • 20
                    #49
                    I uploaded a number of photos of the boards.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #50
                      You have 4 transistors sandwiched in between the 2 transformers, but I can't make out the PCB designation because your photos are not clear enough.
                      They might be c5707s. You can test them "in circuit" without desoldering them for shorts. Measure the ohms between B-C, C-E, B-E. Any reading less than 30 ohms suggests a shorted transistor.
                      • ryszardx
                        • Feb 2011
                        • 20
                        #51
                        They are 13n07 4c37e. I checked them in circuit and they check out >30 ohms.
                        • ryszardx
                          • Feb 2011
                          • 20
                          #52
                          Any more ideas to help get this monitor up and running!
                          • ryszardx
                            • Feb 2011
                            • 20
                            #53
                            Does anyone have a replacement IPS board for sale for the Dell 1905FP?
                            • alexanna
                              • Mar 2010
                              • 1346
                              #54
                              What is the exact ohm reading you are reading on these transistors?
                              • ryszardx
                                • Feb 2011
                                • 20
                                #55
                                q105 - G-D =12M, G-S = 17.4M, D-S =10.8K
                                q106 - G-D =13.5M, G-S = 17.5M, D-S =12K
                                q107 - G-D =14.8M, G-S = 17.3M, D-S =10.7K
                                q108 - G-D =14M, G-S = 17M, D-S =10.7K
                                • alexanna
                                  • Mar 2010
                                  • 1346
                                  #56
                                  Could you try to get a better picture of the bottom side of the Inv/PS
                                  Overall straight down without a flash, and more in focus?
                                  • ryszardx
                                    • Feb 2011
                                    • 20
                                    #57
                                    Here's a back and front of the board. The board was slightly tilted. I can reshoot if you need it. Ran out of time today. Thanks Rich
                                    • ryszardx
                                      • Feb 2011
                                      • 20
                                      #58
                                      I am getting security token error uploading my photos. I'll try again tomorrow.
                                      • alexanna
                                        • Mar 2010
                                        • 1346
                                        #59
                                        If you have a really good camera, that's 10m or better you're going to into your camera settings and reduce it down to about 5m.Then with some type of photo editor reduce the picture down to 2000x2000 that should allow you to post pictures using managed attachments.
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          For a small footprint photo editor and viewer, Viewprint Pro is hard to beat. And the price is right - free.
                                          PlainBill
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • DanPoka
                                            by DanPoka
                                            02-15-2025, 05:05 AM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • Jesus Coder
                                            Issues Reviving Old Dell 2408WFPb Monitor
                                            by Jesus Coder
                                            I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                                            06-25-2023, 02:33 PM
                                          • ChristianBr01
                                            Dell 34 inch U3419W Monitor with thin stripes on partial screen
                                            by ChristianBr01
                                            I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                                            This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                                            This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                                            Does someone have seen this before?...
                                            05-23-2025, 06:06 AM
