Hannspree HSG1064 5 seconds on then blank screen
Re: Hannspree HSG1064 5 seconds on then blank screen
Rtech, your reply did not get lost. I was just a little confused as all. Thanks for responding.
Update:
I used the 20" ccfl tubes to test the monitor and got some very interesting results. I cant figure out which bulb, if any, is bad. Rather than try to describe verbally what i did i created a picture of what i did hoping that this would better describe it (see enclosed pic).
If you guys would review the enclosed pic and let me know what you think i would be greatly appreciated. I cant figure out which bulb is bad, if any.
If you want me to try any other combinations just let me know and i will.
My first thought was bulb 3 of the 25" might be bad but in one of my tests bulb3 of the 25" was plugged in and 25" monitor did not shut off ......so i dont know what to think at this point.
Could it be something other than a bulb?Comment
Update:
One other thing you should try, is to figure out a way to plug the bulbs 1 and 2 into sockets 3 and 4.
And bulbs 3 and 4, into the 1 and 2 sockets. Then repeat your test with a test bulb.
We are looking for the problem to follow the bulbs.
Al.Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!Comment
alexanna,
I would be happy to do the test. Just a little confused as to what exactly you want me to do and i think its because i have a 20" and 25" with bulbs. So if you could specify exactly what you want connected i will do the test. ie...if you want bulbs 1 and 2 of the 25" plugged into positions where bulbs 3 and 4 of the 25" are connected and similaryly bulbs 3 and 4 of the 25" plugged into the postions where bulbs 1 and 2 of the 25" are located .....i can do this.
Just specify monitor as well as bulb.....well, you get the idea.Comment
Concentrate on the 25” monitor, Use the 20”bulbs for testing the 25”
AlWhatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!Comment
alexanna,
not sure i understand what it is you want me to do. I am really sorry......just a little confused. Also, what edit are you referring to and how would i know where to find it.
again, sorry i dont understand ..........i am sure what you do tell me i will be going "duhhh...of course that what was ment".Comment
quick note:
On the 25" monitor. There are 4 bulbs. Two at top and two at bottom. If i move the board upward, so that i can connect the two top bulbs to the "bottom" connections i wont be able to connect the bottom bulbs to the top connections..........electrical lines are just not long enough.Comment
I am doing my best to try to explain what to try.
On the 25” monitor plug in bulbs 1 and 2 into the 3 and 4 sockets of the 25” monitor, and plug in 3 and 4 bulbs into the 1 and 2 sockets of the 25” monitor.
Then substitute the 20” bulb one at a time into each socket of the 25” monitor
I am hoping that you will see the problem you are having follow your test bulb.
As far as the lengths of the ccfl wiring goes, Flip the panel over
You do not have to hook up the ribbon cable from the logic board to the LCD panel,Please just make sure you let any of the pins of the ribbon touch a ground.
Looking at the thumbnails of your testing,the outcome that seems apparent, is that as soon as you have the bottom 25" bulbs(from the lower 3 diagrams shown), plugged in that is when the problem occurs.and the thing switches off,SO perhaps the voltage to those sockets on the Board is not enough to strike the 25" BUT are OK on the 20".I have just has something similar on a TV, and going over the supposed faulty Inverter transformer and the little caps on the secondaries,and the pins on the lamp sockets,with a soldering iron and a small amount of solder, lo and behold, I must have had a dry(high resistance joint) which I could not see, and it fixed the problem.....must be worth a go methinks ??Comment
alexanna, good suggestion......had not thought about flipping the board over. Good suggestion. Also, i understand what it is your saying to do now.
Rtech, i also liked your comments. I will try alexanna's suggestion to collect additional data but I am hoping its not a bulb thing at all.
thanks ....i may not get to trying this today but by tomorrow for sure.
thanks.Comment
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
If you look at ALL the combinations..........ALL of the bulbs at some time or another are "on"............its ONLY when bulbs 1 and 2 are connected together that there seems to be a problem. But this does not seem like a bulb problem ...........does it?
Any thoughts on what could be wrong with the wiring for the ccfls that would cause this? Again, ALL of the bulbs come on at one time or another if you look at all the combinations.
Rtech had mentioned the following:
"SO perhaps the voltage to those sockets on the Board is not enough to strike the 25" BUT are OK on the 20".I have just has something similar on a TV, and going over the supposed faulty Inverter transformer and the little caps on the secondaries,and the pins on the lamp sockets,with a soldering iron and a small amount of solder, lo and behold, I must have had a dry(high resistance joint) which I could not see, and it fixed the problem.....must be worth a go methinks ?? "
Based on this any ideas on things to try?Comment
Welchs101,I am sorry i can't get into alot of detail right now.
But a ccfl can light and look normal during the two second to back problem and still cause problems,an example would be to have a return wire that has only one or two strands of wire making conection.
Here is what I think may be going on, this type of inverter was discussed in another thread. The inverter transformers are dependent on 2 ccfls because it's like a series circuit.
I think there is either a ccfl that has aged or a wiring problem causing them to require more voltage to light or stay on, and it's tripping the voltage protection. When you substitute the 20” bulb there is enough change in voltage requirement that even the marginable longer bulbs from the 25” monitor will work.
These are just my thoughts, Dose anybody else have any ideas?
From the test results you posted I think you have a problem with bulbs 1 and 2.
Al.
In either case, it is time to open the panel and check the tubes and the wiring.
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by ChrissygizmoHi all, I’ve got a problem I hope someone can help me fixi.
I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...01-11-2025, 03:18 PM -
by dicky96Hi guys
I'm trying to fix this laptop screen
Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
OK so I have the original screen which works but has lines across the bottom quarter of the screen
I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would... -
by Kalman27We have a Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF for repair. The original issue the OLED screen is blank.
We have replaced the OLED screen with the exact model, also we replaced the LCD cable, but no luck.
I think there is something with the motherboard. I don't really have experience with OLED screens so far, so not sure how it should work. I have seen some laptop comes with a separate controller board, but this model does not.
Also, there is an error in Windows device manager - This device cannot start (Code 10) - Intel(R) Serial IO I2C Host Controller...2 Photos -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... - Loading...
