Need some help on what to check next. Still experiencing 2 seconds to black.
Board has been recapped. Backlight comes on and then goes black, image is visible by shining flashlight into screen.
-CCFL tubes appear good, tested with known good ones, same issue. I can see each tube light up briefly. Even tried swapping out 2 at a time.
-Inverter transformers appears good, primary 0 ohms, secondary about 450 ohms (both transformers the same, tested out of circuit)
-diodes/transistors/mosfets appear good, no shorts
Can someone point me where to look next?
thnx!
thnx!
