Viewsonic VG2030WM No Display
  • tervel12
    • Dec 2010
    • 42
    Re: Viewsonic VG2030WM No Display
    I removed D60 and it tests ok out of circuit. I then removed C61 and it is shorted.
    I checked C20, C21, C60, and D10 and they all seem ok (in circuit).
    I am looking for a replacement for C61 but there is nothing stamped on it. How do I find a suitable replacement? I have some other scrap boards that have similar capacitors on them that look to be the same physical size but they are unlabeled as well. Will any similar cap work?
    Thank you.
    • PlainBill
      • Feb 2009
      • 7034
      Thank you.
      Looking at the datasheet for the AAT1164C, it appears this is a 1 uF ceramic cap.
      PlainBill
      • tervel12
        • Dec 2010
        • 42
        I did some research and one of the boards I have laying here has some 1uF caps as well as some other various sizes. I desoldered one of those and placed it into the monitor and VOILA!! It is working!!!
        Thank you very much for all of your help and input. It is greatly appreciated and this is an excellent forum.
        Thanks again!!!
        • jetadm123
          • 2169
          Thanks again!!!
          Good work!! Glad it worked out for you.
            master hoarder
            • May 2008
            • 12170
            Awesome, nice work!
            That's how I do it anyways. Seems to work every time - just match the size and it's all good.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • ledbylight
              M1 A2337 Macbook - No Display, likely due to logic board
              by ledbylight
              Hi all!
              This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
              I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
              11-04-2024, 06:36 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • ohren
              Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
              by ohren
              I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
              I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
              The models launched in 2018 and 2019 respectively....
              09-08-2023, 05:24 PM
            • Yanleb
              LG 60PK550 Logic Control Board EBR63450301
              by Yanleb
              Hi all, I just want to share the repair of my 60PK550-UA TV set.
              The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
              But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
              All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
              C57: 3.30V
              C61:...
              07-20-2023, 12:38 AM
