Iiyama Prolite E430S click sound
  • llphat
    • 20
    Hello All,
    I'm new to this forum and am looking for some advice on fixing a few broken LCD which I have. One of the LCD is a Iiyama Prolite E430S.
    I have taken the monitor apart, on inspection the power supply board is emitting a constant click sound on power up. I have replaced two bulged caps C922 and C925 (1000uF 16V). The click sound still appears but I can't seem to locate where it is coming from. My suspicion is the ZD904 zener diode which might be broken.
    Any help would be appreciated. Thanks in advance
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Iiyama Prolite E430S click sound
    For this monitor and your LG in the other thread, it is always helpful to post clear focused top down view pictures of all your boards (both sides) as close to 2000x2000 resolution using the manage attachement. Please do not post inline.
    The clicking sound is probably the smps trying to startup. The small cap proceeding it is likely bad. It is around 22uF 50V and does not have to bulge in order to be bad. It can be out of uF tolerance or have high ESR (ohms).
    --- begin sig file ---
    --- end sig file ---
    • llphat
      • 20
      Image of photo board now attached.
      I have replaced two 1000uF 16V caps on the top right corner of the power supply board image.
      Indeed there is a 22uF 50V cap next to the IC901 at the bottom right of the photo but I do not have equipment to test. I will find a suitable replacement to see if it solves the problem.
      • retiredcaps
        • Apr 2010
        • 9271
        Lucky guess on my part. They can range from 2.2uF to 47uF.
        This board looks Benq-ish. In particuluar, check Q211 and its partner, Q209 and its partner for shorts.
        BTW, the cap just right of J210 has the sleeve partially burnt off. Since caps are farily inexpensive (less than $1), I suggest you replace that one in case there is damage to it?
        • retiredcaps
          • Apr 2010
          • 9271
          If you measure the voltage across this small cap, does the DC voltage fluctuate or is it steady? Please list the measurement.
          • llphat
            • 20
            Image of the back of the power supply board attached.
            Initially I had suspected ZD904 at the top left of the image as it looks rather burnt.
            I had just tried to measure the voltage across C907 the 22uF 50V cap. When I put a voltmeter across it the clicking sound slows down, reads around 15V steady but when it clicks (now slower) the voltage drops to about 10V.
            • retiredcaps
              • Apr 2010
              • 9271
              1) You can measure ZD904 "in circuit" with the diode check function on the multimeter.
              2) PlainBill talks about pulsing on the small cap ...
              https://www.badcaps.net/forum/showpo...48&postcount=4
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • mikey5791
                Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                by mikey5791
                Got this working ips led monitor by the brand of
                Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                09-04-2023, 03:50 AM
              • LEECH666
                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                by LEECH666
                Good day ladies and gentleman!
                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                01-19-2024, 05:46 PM
              • Christos Tsiligiannis
                Marian Trace Alpha sound card repair help
                by Christos Tsiligiannis
                Hello to the forum.
                My name is Christos, I am new to the forum here and i am posting from Greece.
                So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                So i tried asking for a schematic from the company and they would not give me one. Instead they...
                11-18-2024, 05:26 AM
                HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                09-12-2024, 02:30 PM
