Fixing a DAC-19M005 Power Supply - check my DX:
  • viziks
    • Mar 2012
    • 33
    • India
    #101
    Re: Fixing a DAC-19M005 Power Supply - check my DX:
    Hello Guys I have a blown FET Q206 and resistor R210 burnt.
    I understand from previous posts that R210 is 10ohms ,was wandering which transistors are Q201,203,204 and 209.
    Also can "blackrider1" please post the schematics again as the Megaupload site has been taken down.
    Samir
    • alexanna
      • Mar 2010
      • 1346
      #102
      Samir
      Post 74 has the parts list for the transistors.And post 83 shows the schematic
      • viziks
        • Mar 2012
        • 33
        • India
        #103
        Thanks ,I found the schematic and parts list as pointed out by you.
        • ned1
          • Feb 2014
          • 139
          • usa
          #104
          So whats the part number for Q201 it says K7.2 on the part
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            03-31-2024, 02:12 PM
            07-01-2024, 06:34 AM
          • karatzdi
            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
            by karatzdi
            I know some might say... just buy another one. Sell it as parts..!
            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
            Spent some time downloading the Service...
            06-11-2024, 08:38 AM
          • gica69
            Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
            by gica69
            I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
            Resistor shows orange range silver gold and green lines.
            Thanks in adv...
            07-21-2025, 09:49 PM
