HP 1825 Display Black Power Light Green
  • printone2
    replied
    Re: HP 1825 Display Black Power Light Green
    Originally posted by retiredcaps
    If these are good lamps, I just leave them in their lcd housing and stretch the cables from the other monitor for testing. You don't need to build anything fancy.
    Thanks.
  • retiredcaps
    replied
    Originally posted by printone2
    How can I use the good lamps to test problems on other panels?
  • printone2
    replied
    PROBABLY a 5A fast blow. F= fast blow T=5Amp
    PlainBill
    I replaced the smd fuse with SF-1206F500-2CT-ND from Digi-Key, it is a 5 amp fast smd 1206. That along with the 22uf 25v caps on the inverter made the difference. I recapped the image card and the power supply with samxon's from badcaps.net and now two of the three panels appear to work fine. The third panel has a smashed screen, but the image and power boards are fine.
    How can I use the good lamps to test problems on other panels? I seem to have read about a kit to test lamps with. Where are plans for such a kit?
    Thanks everyone.
  • PlainBill
    replied
    The good fuse at F1 has the letters "FT" on it.
    PlainBill
  • printone2
    replied
    A good picture of F1 would help. it's probably in the 2-4 amp range, but most SMD fuses have a single letter on them which identifies the rating.
    PlainBill
  • PlainBill
    replied
    I have one fuse on one inverter board that is good, but how do I tell what a replacement fuse should be for two boards that the bad caps caused the fuse to blow? The fuse is located at F1 on the inverter and is an smd. I have put a temporary glass 4amp fuse in place of the blown fuse. It seems to work fine, but I am not at all sure if that is a reasonable value for the replacement. I would like to have a few standard fuses on hand. Can someone suggest some normal ones to keep around as spares as well as suggest what might be reasonable for location F1?
    PlainBill
  • printone2
    replied
    I found the F1 fuse on the inverter board and yes they are blown on both of the bad inverter boards and good on the functioning board. Now what caused it? I still have to check the mosfets.
  • printone2
    replied
    When replacing my caps I see that I made a mistake in measuring the height of the caps. It should read that the 470uf 25v caps are 10mm wide and 16 mm high. The two caps on the inverter are 7 mm wide and 5 mm high and 22uf 25v. Both of these caps were bad and appear to be the reason for the bad smd fuse at location F1.
    After replacing these items with some temporary caps and a temp fuse the panel lights up.
    Thanks again for everyone's help.
  • printone2
    replied
    Originally posted by jetadm123
    The purpose of the resistance check is for one purpose only: to locate a short between the S,D or G pins of the mosfet. Since mosfets are made differently than a BJT transistor, you cannot strictly use a resistance test to verify that a mosfet is good. However, in the case of a mosfet failing on an inverter, they generally will short out and that's what we're looking for. Therefore, don't expect to find a "normal" reading resistance wise. So, if you don't see a short using the suggested test methods, then move onward.
    Now here is a newbie conclusion, that as long as there is some resistance then it has not shorted out, so only a low ohm reading would indicate a bad mosfet?
  • jetadm123
    replied
    I did a poor job of laying out the mosfet readings. The readings I took are pretty different on the second board (functional board than the other two), but I do not know what normal readings should look like. On the 4416 the working lcd has readings on most leads tested, but the non working panels have over limit readings on most leads. I will read some more.
    The small purple caps are sanyo brand, so a better quality than the capxons populated on the rest of the boards from what I am reading.
  • printone2
    replied
    Doesn't look like anything is shorted assuming that 4435 with the ? marks are good.
    Here's what I suggest: take one of the "bad" inverter boards and remove fuse F1. Instead of replacing that fuse with another SMD fuse (they are a little pricey) go to Radio Shack and purchase a cheap fuse holder for glass type cartridge fuses. Not sure what amperage fuse to purchase. Go ahead and replace the 2 purple caps. If it doesn't solve the problem and blows the fuse again, at least you'll be able to use much cheaper glass fuses until the problem is resolved. Once the problem is solved, then go ahead and purchase the correct SMD fuse.
  • jetadm123
    replied
    All the work to make the columns line up was worthless. The "?" meant that I did not measure that parameter. The first reading in each line represents board 1, then board 2 and finally 3. Board #2 is the one that is working.
    Yes the overlimit readings are in excess of 200ohms.
  • printone2
    replied
  • jetadm123
    replied
    Here are the readings from the Mosfets: (">" represents overlimit, ohms
    set manually at 200 ohms)
    4416 Board1 Board 2 Board 3
    (1of2) (working)
    S-G 153 199 147
    S-D > 162 >
    G-D > > >
    (2of2) (working)
    S-G > 167 >
    S-D > 132 >
    G-D > 131 >
    4435 Board1 Board 2 Board 3
    (1of2) (working)
    S-G > 142 >
    S-D 84 111 >
    G-D > 191 >
    (2of2) (working)
    S-G > 134 186
    S-D ? ? ?
    G-D > > >
    And the fuse on the inverter labeled F1 is not good on the two inverter boards that are not working.
    Thanks.
    Looks like the spacing you used for each column didn't come out as planned. Some of the wording came out under the wrong column and added some confusion. I would like to verify that when your meter reads over limit, it means the reading is over 200ohms? Also, on the last reading S-D of the 4435, what does the ? mark mean?
  • printone2
    replied
    Datasheet for 4416
    Datasheet for 4435
    If you have a manual range multimeter, set it to 200 ohms (two hundred). You can test a mosfet (Q, IC designation) "in circuit" by (power off and unplugged)
    a) black on pin 1- red on pin 2 - record ohms
    b) black on pin 1- red on pin 3 - record ohms
    c) black on pin 2- red on pin 3 - record ohms
    If any ohm reading is less than 30 ohm you might have shorted mosfet. Remove from circuit and repeat the tests to verify.
    Some mosfets are more than 3 pins. To test those, identify the part number and search for its datasheet. Once you find the datasheet, the pins will be designated source (S), gate (G), and drain (D). It will probably be documented as S1, S2, G1, G2, D1, D2.
    Simply test
    a) black on pin S1- red on pin G1 - record ohms
    b) black on pin S1- red on pin D1 - record ohms
    c) black on pin G1- red on pin D1 - record ohms
    Repeat for the "2" pins. That is S2-G2, S2-D2, G2-D2.
    (1of2) (working)
    S-G 153 199 147
    S-D > 162 >
    G-D > > >
    (2of2) (working)
    S-G > 167 >
    S-D > 132 >
    G-D > 131 >
    (1of2) (working)
    S-G > 142 >
    S-D 84 111 >
    G-D > 191 >
    (2of2) (working)
    S-G > 134 186
    S-D ? ? ?
    G-D > > >
    Thanks.
  • printone2
    replied
    1) verify the fuse F1 is good.
    2) on your photo of the inverter: looking at the top there are two 8-pin surface mount chips on the outside of each purple cap. I believe these are mosfets (possibly duo mosfets) that generate the sine wave for amplification by the inverter transformer to power the CCFL's. These should be checked for shorts using your DMM.
    3) if the mosfets check good, then you can always try changing the two purple caps.
  • printone2
    replied
    The only fuse I see is the one near the power plug on the power supply and they check out as good. I will do some research on how to test mosfets.
  • jetadm123
    replied
    Well I am not quite done yet. It looks like two of the inverters are bad, but I do have one good one. I have swapped inverters between two of the panels and determined that the lamps, power supplies and image cards are good in all three panels, but I have two bad inverters. What is the easiest way to compare the bad inverters to the good one?
  • printone2
    replied
    Great to hear that! Good work!
  • jetadm123
    replied
  • MOSSEP
    Monitor Audio RSW12 - Green light, but no sound
    by MOSSEP
    Hi
    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
    I have already tried replacing all of the...
    01-26-2025, 08:33 AM
  • MOSSEP
    Monitor Audio RSW12 - Green light but no audio
    by MOSSEP
    Hi
    01-26-2025, 08:18 AM
  • lcdcaps1
    820-2610-A Sys onewire help, no green light. Please help from the gurus
    by lcdcaps1
    Hi
    I have an 820-2610-A motherboard that has no green light.
    I have noticed is when I do a SMC reset the light on the Magsafe blinks.
    From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
    The sys onewire circuit on this model and others is more involved
    I was hoping if anyone knows about this and how it works, can reply and let me know
    I know this is an old model but I am sure there are people who still works on these or knows about them
    I get 1.1v on the C7771 capacitor and will replace...
    11-06-2023, 01:28 PM
  • blazzelia
    MBP A1286 820-2915 green light only, no start
    by blazzelia
    Hi guys,
    I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating...
    09-30-2024, 07:20 AM
  • jheunne
    A1466 macbook no boot green to orange light help
    by jheunne
    i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
    in first image there is 0v out for lcd
    https://ibb.co/5XppmpkH
    in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
    https://ibb.co/fdJkbJs8
    06-10-2025, 10:52 PM
