2 Viewsonic VX1940W buzzing and no signal
  • briand
    RocketScientist
    • Jan 2011
    • 12
    Re: 2 Viewsonic VX1940W buzzing and no signal
    thanks for the suggestions.
    attached is my DigiKey order... I would appreciate verification that I selected a suitable replacement for the 120uF/400V capacitor.
    • retiredcaps
      • Apr 2010
      • 9271
      Assuming the diameter and height are correct, Panasonic is fine.
      --- begin sig file ---
      --- end sig file ---
      • briand
        RocketScientist
        • Jan 2011
        • 12
        ...for those following along at home and/or vicariously repairing monitors through my experience, I've attached an image indicating the parts being replaced.
        C1 and C302 are definitely bad (bulged)
        C201 is questionable.
        C205, C305, and C307 are being replaced in a preventative manner, as they are of the same quality as the failed capacitors (5x CapXon, 1x VENT). All being replaced by Panasonic caps.
        • Kridian
          • Sep 2010
          • 39
          Post an after pic on the new ones installed.
          • briand
            RocketScientist
            • Jan 2011
            • 12
            okay, I will.
            life may intervene, so it may be a week or two before I get around to completing the repair.
            • Neobyte
              Learning..
              • Jan 2011
              • 12
              #26
              first msg on this great forum. Finally found this thread I was looking for. My monitor is model VX1940wm to be exact.
              I have _exactly_ the same story as briand. Had VX922 and it was replaced to this monitor and it failed too. First time I changed only the 2 bulged caps, and the monitor worked like 1-2 month(s). After the first repair, one vertical cyan line appeared on the screen after heating up. By pressing the screen the line disappeared. Don't know it this is due some bad connection or connector.
              Anyways, the monitor went completely dead. Decided to change all caps then and I'm also waiting the parts now. I will get back when I get it completed :P
              • briand
                RocketScientist
                • Jan 2011
                • 12
                #27
                welcome to the forum, Neobyte.
                my parts are in-transit. Digi-Key backordered one of the caps, so I ordered it from Mouser... also found a 120uF/400V radial lead replacement (Nichicon) at Mouser as well; the Panasonic unit from Digi-Key was a 'snap-in' with two short posts.
                I should, hopefully, have all the parts by mid-week, and have my 19" WS monitor back online by next weekend.
                • Neobyte
                  Learning..
                  • Jan 2011
                  • 12
                  #28
                  Recapped the monitor now. Didn't help anymore. Must be some other component failing? Don't know what. Here's image of the smps-board..
                  It's trash unless someone figures any tricks
                  • alexanna
                    • Mar 2010
                    • 1346
                    #29
                    What do you mean completly dead?Have you checked all the fuses?
                    Al.
                    • Neobyte
                      Learning..
                      • Jan 2011
                      • 12
                      #30
                      No power at all. Power led doesn't go on. Ermm, I found 3 fuses total, F1 (surface mount) on the 'long board', and psu-board F101 and F301. They all measured close to 0 ohms. Dunno if there's more of them? :P
                      • showmemule
                        • Jan 2011
                        • 16
                        #31
                        Originally posted by wcperki
                        The 2 Viewsonic X1940W LCD monitors I bought as a dual monitor set are both not working. They are still underwarranty but I could'nt help myself I had to take one apart. I could use some help getting the right caps ordered.
                        I tried mouser and digikey but gave up. I'd prefer to just order from badcaps.net but here too I run into a roadblock with exact matches.
                        I'd like to know what I can safely use to replace the following caps. Also, can anyone tell me how does one remove the epoxy glue inorder to de-solder?
                        Pictures are attached.
                        C1
                        CapXon
                        GF105
                        P735 vent
                        220μF 35v
                        D=10mm x L=12mm x LEAD SPACE=5mm
                        C302
                        CapXon
                        GF105
                        P735 vent
                        220μF 35v
                        10mm x 12mm x 5mm
                        C305
                        CapXon
                        GF 105 c
                        P735 vent
                        2200μF 10V
                        13mm x 18mm x 5mm
                        C307
                        CapXon P735 vent
                        KF 105c
                        1000μF 10V
                        8mm x 20mm x4mm
                        C205
                        KF105 P733
                        50V 22μF
                        5mm X 8MM x 3mm
                        Thanks,
                        Warren
                        First make sure the caps are bad. Second you can carefully cut the glue with an exacto, avoiding board scaring, these caps you list can be found in other power supplies and controls. Just be sure to check the replacements before install. K!
                        • showmemule
                          • Jan 2011
                          • 16
                          #32
                          Can someone tell me if there is an nte, or other cross number for a 13n07 mos transistor out of a dell 1704fpt
                          • PlainBill
                            • Feb 2009
                            • 7034
                            The power LED is a 'fly by wire' arrangement. It is controlled by the processor on the signal (logic) card. Check the output voltage of the power supply. If that is missing, check the voltage across the large (100uF, 450 volt) cap. If the output voltage is present, check for a reset controller on the signal card.
                            PlainBill
                            • Neobyte
                              Learning..
                              • Jan 2011
                              • 12
                              #34
                              PlainBill, I tried to measure the voltages. I suppose the output is the connector going to the logic board? There wasn't much voltage present. Then I checked the large cap, the voltage was ~105V. Is that toasted too? (I did not change that during my recap operation)
                              edit: Btw I have 230V mains.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                How are you measuring that voltage across the large cap. Is that 105 AC or DC that you are measuring?
                                • Neobyte
                                  Learning..
                                  • Jan 2011
                                  • 12
                                  #36
                                  Black, ground from the corner screw area and red to the positive leg of the cap. My meter was at 600V (DC).. I don't have too much experience measuring these things.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    To measure the DC voltage across the large cap, put your black in COM and red into Volts on your multimeter.
                                    Then put your black probe on the negative leg of the main filter cap. Put your red probe on the positive leg of the main filter cap.
                                    You should get 230V x 1.414 rectified DC voltage or about 325V DC.
                                    • Neobyte
                                      Learning..
                                      • Jan 2011
                                      • 12
                                      #38
                                      Ok, I got 321V from there
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        Okay, let's retest for the secondary voltages.
                                        Put your black probe on a screw near the connectors. This is your ground. Put your red probes on each connector (CN301) and report each DC voltage on each connector pin. Put your multimeter on 20V DC.
                                        edit: Pin 1, 2, and 3 according to the legend should be 5V DC.
                                        • Neobyte
                                          Learning..
                                          • Jan 2011
                                          • 12
                                          #40
                                          Yes it should be 5V. Every pin shows close to zero voltage (maybe it's zero then). <0,1V anyways.
                                          • dcbw
                                            PowerMac G5 ACBel 614-0303 buzzing
                                            by dcbw
                                            The PSU works, but shortly after powering on (either in the G5, or by shorting the power-on pin to ground) it begins buzzing loudly. It also makes the LED lights connected to the same circuit flicker. It's definitely a buzzing, not a high pitched whine.
                                            The buzzing seems to come from the high voltage side of the board, perhaps from the white relay. Could the relay be bad, or could the 5V supply be bad enough that it's unable to keep the relay on? Any pointers to help isolate the issue? Thanks!
                                            Other info: API2FS34, ID 291, Date B0404
                                            05-31-2024, 07:13 AM
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
                                          • stvhop
                                            HP1955L Buzzing noise & interference
                                            by stvhop
                                            Hello, This is my first post so please forgive me if I miss out some vital info.
                                            I have a problem with my HP1955L monitor from 2005.
                                            The first thing to say is that it is still basically working, ie the picture is fine.
                                            However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
                                            The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
                                            11-07-2020, 07:13 AM
                                          • reessi
                                            Hanns-G HG281D - LCD Monitor - Low B/L voltage and loud buzzing...
                                            by reessi
                                            The pics are off the other really long thread as they are much clearer than my phone will do.
                                            The fault:
                                            In standby there is no buzzing.
                                            After signal input and turn on, a loud buzzing is emitted from the main transformer, no backlight.
                                            It is because the 24v line is at 21v irrespective of whether the inverter is plugged in. There is a picture on the screen.
                                            If you wait long enough the buzzing stops and the 24v line changes to 24v and the inverter comes on.
                                            I have checked every single cap on the psu and logic board by un-soldering...
                                            07-05-2020, 05:23 AM
                                          • StefanNg
                                            Viewsonic VX2718-PC-mhd SG2701B01-8
                                            by StefanNg
                                            Hi, Badcaps.
                                            I am troubleshooting a monitor
                                            Viewsonic VX2718-PC-mhd.
                                            Panel model SG2701BSG2701-8
                                            Symptoms is no image.
                                            This panel has 2 panel board connected by a U-ribbon.
                                            When I disconnected the ribbon, I get a perfect half screen image.
                                            I took some test point voltage, when ribbon disconnected.
                                            HVAA 8.38v
                                            FVDD12 1.21v
                                            FDD33 3.3v
                                            VIN 11.79v
                                            VAA 16.85v
                                            VGHF 30.16v
                                            VGL -8.02v
                                            CK1_I ~ CK8_I 1.403v
                                            CK1_L ~ CK8_L 8.26v
                                            When I connect both panel board
                                            HVAA, VGHF, and CKx_L...
                                            05-17-2025, 01:43 AM
