Optiquest Q7 Power Supply
  • TX-ZoSo
    • Dec 2010
    • 8
    Re: Optiquest Q7 Power Supply
    Well, replaced all of the said caps minus the primary with Panasonic FC. I'm still getting the same orange light after a few seconds. Aside from the possibility that the primary failed, I'm stumped.
    • mockingbird
      • Dec 2008
      • 5484
      Let's have a look at the logic board.
      • jetadm123
        • 2169
        Can we get some pics of the entire power (top and bottom) and logic boards? No inline pics, use PlainBill's links in post #12.
        Also, do you see any evidence that the backlights are attempting to start, like a brief flash?
        • lcdman
          TinkerTech
          • Nov 2010
          • 232
          • U.S.A.
          Did you ever find the large cap. I have some if interested. I'll send ya some, do you use PayPal? If so send me a private message and we can discuss.
          Also A New Member,
          lcdman
          • retiredcaps
            • Apr 2010
            • 9271
            I'm still getting the same orange light after a few seconds..
            Does the backlight flash on for 2 seconds like before?
            --- begin sig file ---
            --- end sig file ---
            • TX-ZoSo
              • Dec 2010
              • 8
              #26
              I'll get some pics up first thing tomorrow.
              Yes, the backlight does come up for a second or two. Displays "RGB No Input Signal!".
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                Hookup a computer and verify you can see the image. If you can see the image, then you have what is called "2 seconds to black".
                It is not uncommon for a LCD monitor to have more than one problem. Your first one was the bloated caps. The second one could be a bad inverter transformer or bad ccfl/wiring. See post #13 and #14 at
                https://www.badcaps.net/forum/showthread.php?t=10419
                on how to begin. I would focus on sections #4 and#5 to start.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Wait a minute! In post #1, you said the big cap read "well below 100uF, more like .1 nF".
                  Did you not order a replacement cap if the uF is reading well below spec? If you did order the big cap, why did you not replace it as well?
                  • TX-ZoSo
                    • Dec 2010
                    • 8
                    #29
                    I went on the assumption that it was unlikely bad. I remember testing it with a meter and getting a reading of 98uF once and every other time being in the nF range. I'll order a replacement.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      Before you order a replacement, with a computer hookedup do you see an image during "2 seconds to black"?
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                        03-31-2024, 02:12 PM
                        07-01-2024, 06:34 AM
                      • CMCM
                        Russound CA4 Power Supply Repair
                        by CMCM
                        Hello Everybody,
                        Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                        Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                        The outputs marked 12v and 20v are all measuring only 1v.
                        The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                        The capacitors physically look clean (no bludgesor leaks) and...
                        07-03-2025, 01:12 PM
                      • JimBanville
                        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                        by JimBanville
                        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                        09-13-2023, 07:21 AM
