Optiquest Q7 Power Supply
  • TX-ZoSo
    • Dec 2010
    • 8
    I've got an Optiquest Q7 LCD that stays on for about 2 seconds and then the display drops out. I've disassembled the monitor and found several bulging caps on the power supply board. (circled in blue in attatched picture)
    These consist of the following:
    3x CapXon 470uF 25V "KF 105^o C C610 VENT"
    1x CapXon 330uF 25V "KF 105^0 C C612 VENT"
    The big guy (outlined in red) is a CapXon 400v 100uF, reading at well below 100uF, more like .1 nF.
    My main question is really just to get a recommendation for ordering parts for this repair.
    Any help would be appreciated.
  • TX-ZoSo
    • Dec 2010
    • 8
    Re: Optiquest Q7 Power Supply
    The first post didn't seem to attach the image, so here it is.
    • retiredcaps
      • Apr 2010
      • 9271
      The forum members here often say that the big cap rarely, but not never, fails. Here is a good example of a big cap that has failed measuring well below its uF.
      There is no picture, but if you follow PlainBill's instructions below, you can order Panasonic FM caps at digikey.com
      https://www.badcaps.net/forum/showpo...33&postcount=2
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        Please don't post images inline or use offsite hosting. Use the manage attachments. If your pic is 2000x2000 and less than 2MB, it should load fine here using manage attachments.
        The advanced edit button will let you correct your inline post.
        Otherwise, it is clear excellent focused picture.
        • retiredcaps
          • Apr 2010
          • 9271
          Replace C320 as well too. It plays an important role in the startup process. Since every other capacitor on the board as failed, it would not be a stretch to think that C320 is near its useful life.
          Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad.
          • TX-ZoSo
            • Dec 2010
            • 8
            Excellent. Thanks for the prompt response.
            • mockingbird
              • Dec 2008
              • 5484
              I've never had a Capxon primary fail on me, but I would replace Taicon primaries on sight.
              • jetadm123
                • 2169
                What's with the large 470 ohm 5W Xicon resistor acoss the primary cap?
                • TX-ZoSo
                  • Dec 2010
                  • 8
                  I used it to make sure that the cap was discharged. Forgot to remove it before I snapped the pic.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    I did a test on one of my monitors and it doesn't apply to all monitors, but I hooked up my multimeter to the big cap and measured 160ish V DC.
                    I powered off and unplugged the power cord. I watched the multimeter and saw the big cap discharge over about a 1 minute period.
                    • TX-ZoSo
                      • Dec 2010
                      • 8
                      Ah, I'm used to working on tube amps. The filter caps in those must have gotten me paranoid.
                      Good to know that these discharge that quickly though.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        There is a high value resistor (100K) that provides startup power to the SMPS controller that will discharge the large cap fairly quickly. However, that resistor going open is one (rare) failure mode for the power supply.
                        The moral is: Better safe than sorry.
                        PlainBill
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Agreed.
                          In fact, I switched the way I measure the main filter cap by using aligator clips on my multimeter. I clip everything in, double check all my connections/polarity, and then hit the power bar switch. That is how I did the above test.
                          • jetadm123
                            • 2169
                            PlainBill
                            I agree with PlainBill. I always first check the voltage across the main cap before I do anything else. This rule applies to everything run off of line voltage. SAFETY FIRST!
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              Originally posted by jetadm123
                              SAFETY FIRST!
                              Can't agree more, been zapped last month by a 17" LG Flatron (crt) that had an open bleeder resistor on the primary cap. Not fun.
                              A working TV? How boring!
                              • BlexClex
                                • Dec 2010
                                • 5
                                Hi all, this is my first post. I fixed an LCD monitor about a month ago by replacing a cap. Yesterday, I tried fixing my Optiquest Q7 monitor by fixing 4 bad caps. Problem is, when I had the new caps soldered in and went to power on the monitor nothing ever happened. I was checking over other parts and found that the L660 was loose. I removed it and am now looking to replace.
                                Go figure, I see this post which is almost exactly related to the power board I'm correcting!!
                                The image previously shown in this thread is the same as my power board.
                                The thing is, what IS in the L660? Its a tiny half a centimeter black rod that had copper rapped around it. I need to get a new one but I just can't locate what it is.
                                Can anybody help?
                                Also, on the Q7, does anybody have the CN1, CN2, CN3, CN4 connector color code for reconnecting the display to the power board?
                                Thanks in advance!!
                                • jetadm123
                                  • 2169
                                  Can anybody help?
                                  Thanks in advance!!
                                  If L660 was loose because of a bad solder joint and if there's no physical damage, just go ahead and solder it back in. The black rod is ferrite.
                                  • BlexClex
                                    • Dec 2010
                                    • 5
                                    Thanks, but I ripped the copper off of the black rod. I'm assuming I just place the black rod back on, wrap some of the left over copper around it and put it back in? Thank you again!
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      L indicates inductor. It is a number of turns of wire, often with an iron or ferrite core. The core material, number of turns, and to a certain extent the gauge of wire are important. When you say 'left over copper' it gives the impression that some of the wire is missing. Is that correct?
                                      PlainBill
                                      • BlexClex
                                        • Dec 2010
                                        • 5
                                        Yes, I pulled the iron or ferrite core out and pulled the wiring off of it too. There is one piece of wire left in one of the two L660 slots and it's about 3 inches long currently.
                                        I figured I could easily buy a replacement one but it's turned out to be a lot more complex of a replacement than I thought.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          03-31-2024, 02:12 PM
                                          07-01-2024, 06:34 AM
                                        • shamsudeen
                                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                          by shamsudeen
                                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                          07-19-2025, 07:14 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
