Dell E177FPf chirps
  • FuriousCaps
    • Dec 2010
    Dell E177FPf chirps
    I've taken the unit apart and can clearly see at least 4 caps are bulging. I have not replaced those yet because I am curious about an observation I made.
    When the ribbon cable to the LCD is plugged in the power light blinks and there is a chirping sound that repeats at each blink (sound like a friendly version of a movie laser blast almost). With the ribbon cable unplugged the power board will turn on solidly. Should I start by replacing the bulging caps or is the chirp problem likely something else?
    I'm not sure what voltages, etc to check but I've read the notes from the other E177FPf thread: https://www.badcaps.net/forum/showth...hlight=e177fpf
    I'm showing solid voltages across U850 and U802 the amount of which of course depends on which pins are checked.
    *If you reference the picture the bulging caps are C864, C869 (470uf 25v), C862 (1000uf, 25v), C1 (220uf, 25v). 864, 869, & 862 are the three barrel caps straight up from the big blue 450v cap. The other is on the left side.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell E177FPf chirps
    Start by replacing ALL the caps first. I count 10 capacitors not including the big one. The big one rarely, but not never, fails.
    Since 4 out of the 10 caps obviously failed, it would not be a stretch to think the other 6 are near their useful life.
    Caps don't have to be bloated to be bad. They can be out of uF tolerance (1000uF measures 25 uF) or have high ESR (ohms). Caps also dry out from heat.
    Use low ESR caps from this list ...
    https://www.badcaps.net/forum/showthread.php?t=2280
    You can buy them from here to support this site or big distributors like digikey, mouser, etc.
    --- begin sig file ---
    --- end sig file ---
    • jetadm123
      • 2169
      In the days of the caveman: bulging caps BAD!............new caps GOOD! Seriously, replace ALL the caps except for the large 450V? one (unless it's bulged or leaking) with low-esr ones like Panasonic FM or FC series available through digikey.com if you're in the USA. It should also remedy the chirping unless there are other problems you didn't mention.
      • FuriousCaps
        • Dec 2010
        I don't mind buying from here and supporting the site but I can find all but 6 to buy from here. There are 12 barrel type caps on the board (two under glue). It seems like a waste of money to buy from two places since I'll have to pay shipping twice.
        The items I can't find from badcaps are 47uf 16v, 10uf 50v.
        • retiredcaps
          • Apr 2010
          • 9271
          I agree with paying shipping twice. Get them for digikey or mouser. They are likely to have all your choices.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • re-atari
            Denon AVR-X2000 mainboard caps bulging
            by re-atari
            I have been using a Denon AVR-X2000 receiver in my living room for several years now, works perfectly, am very pleased with it. Recently I acquired another one, advertised as defective with flashing red led a few seconds after switching on. Picked it up to try repair and use in hobby room. After switching on, the on/off indicator led indeed initially flashes green for about 2 seconds, during which the display is visible, and then starts flashing red (at 2Hz) with a switched off display.
            I'm afraid the service manual is too large to upload here (55Mb), it can be found at https:/...
            09-23-2020, 10:37 AM
          • huzo
            DELL Latitude 3500 no image, fan max speed, caps lock frozen
            by huzo
            Dell latitude 3500
            Board BOLT-L UMA MB
            17938-1
            FW8G6$LA
            when i press the power, fan goes full speed, power button lights up , and caps lock light is on, the screen polarises, goes dark,no backlight...All voltages present, except PL4701, but that's probably for GPU power later....
            I've tried a few dumps from posts, it always acts the same, so i thin it's not a bios issue...
            No shorts found on the board...
            What should i try next?
            10-06-2024, 02:15 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
