Monitor LCD DELL E153FPD
+ More Options
Posts
  • rkawa
    Richard
    • Nov 2010
    • 10
    https://www.badcaps.net/forum/images.../icon4.gifHola! tengo problema con un Monitor DELL E153FPD.
    PLEASE I NEED ME ON THE FAULT EAST.
    * NO MONITOR SIGNAL LIGHT, BUT NOT AS LIGHT LAMPS CAN TRY?
    ANYONE HAVE A MANUAL SII ON THE SOURCE OF THE MONITOR
    AND IF YOU COULD PROVIDE ME .......
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Monitor LCD DELL E153FPD
    no hablo espanol
    en ingles por favor as muy bueno
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by rkawa
      [url]
      If this is anything like the other Dell monitors, it uses a Benq board. In addition to potentially bad caps, they have numerous problems and are summarized with fixes by PlainBill. A picture is also included so you can check all the necessary components.
      See post
      https://www.badcaps.net/forum/showpo...&postcount=128
      --- begin sig file ---
      --- end sig file ---
      • rkawa
        Richard
        • Nov 2010
        • 10
        Yes, indeed is a board with benq (ic751: Tl1451acn), good and put a light behind you seen this working
        • retiredcaps
          • Apr 2010
          • 9271
          If you can see the display by shining a flashlight, you probably have one or more
          1) open fuse
          2) shorted c5707 transistors
          3) shorted fu9024
          You can buy "kits" on ebay to get all thse components. See
          http://cgi.ebay.ca/REPAIR-KIT-E172FP...item3362aa38ac
          • rkawa
            Richard
            • Nov 2010
            • 10
            THANKS FOR THE INFORMATION, AND THEN I get to work on those components ....
            ATTE: RICARDO. MEXICO CHIAPAS
            • Borse2008
              Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
              by Borse2008
              Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
              I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
              • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
              • There’s
              07-15-2025, 04:55 AM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • DanPoka
              Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
              by DanPoka
              I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
              Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
              This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
              02-15-2025, 05:05 AM
              by momaka
              03-15-2023, 10:17 PM
            • Jesus Coder
              Issues Reviving Old Dell 2408WFPb Monitor
              by Jesus Coder
              I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
              06-25-2023, 02:33 PM
