Monitor LCD DELL E153FPD
  • rkawa
    Richard
    • Nov 2010
    • 10
    https://www.badcaps.net/forum/images.../icon4.gifHola! tengo problema con un Monitor DELL E153FPD.
    PLEASE I NEED ME ON THE FAULT EAST.
    * NO MONITOR SIGNAL LIGHT, BUT NOT AS LIGHT LAMPS CAN TRY?
    ANYONE HAVE A MANUAL SII ON THE SOURCE OF THE MONITOR
    AND IF YOU COULD PROVIDE ME .......
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Monitor LCD DELL E153FPD
    no hablo espanol
    en ingles por favor as muy bueno
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by rkawa
      [url]
      If this is anything like the other Dell monitors, it uses a Benq board. In addition to potentially bad caps, they have numerous problems and are summarized with fixes by PlainBill. A picture is also included so you can check all the necessary components.
      See post
      https://www.badcaps.net/forum/showpo...&postcount=128
      --- begin sig file ---
      --- end sig file ---
      • rkawa
        Richard
        • Nov 2010
        • 10
        Yes, indeed is a board with benq (ic751: Tl1451acn), good and put a light behind you seen this working
        • retiredcaps
          • Apr 2010
          • 9271
          If you can see the display by shining a flashlight, you probably have one or more
          1) open fuse
          2) shorted c5707 transistors
          3) shorted fu9024
          You can buy "kits" on ebay to get all thse components. See
          http://cgi.ebay.ca/REPAIR-KIT-E172FP...item3362aa38ac
          • rkawa
            Richard
            • Nov 2010
            • 10
            THANKS FOR THE INFORMATION, AND THEN I get to work on those components ....
            ATTE: RICARDO. MEXICO CHIAPAS
            • Borse2008
              by Borse2008
              • There’s
              07-15-2025, 04:55 AM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • DanPoka
              by DanPoka
              02-15-2025, 05:05 AM
              by momaka
              03-15-2023, 10:17 PM
            • Jesus Coder
              Issues Reviving Old Dell 2408WFPb Monitor
              by Jesus Coder
              I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
              06-25-2023, 02:33 PM
