Mac A1990 Screen
  • ian G
    • Nov 2023
    • 7
    Mac A1990 Screen
    Need some advise on an unknown history Mac 1990 that I have bought,
    Issues relate to what could be described as a water mark on some areas of the screen, This is only visible on a white background, Shows a blue type breakthrough, or patch on some areas.
    Using an external monitor the external monitor is clean (No issues)
    ? Is this a backlight issue (Reflective layers) or is it the main LCD that is the issue.
    I have noted the cost difference for just replacement layers ($10) against $400 for a LCD unit.
    I do have the capability to remove the screen (Full ESD mat and grounding strap will be used) along with an Air tool for removal.
    Just like to know anyones thought on this in, order to be prepared with the correct items before proceeding further,
    Regards Ian G
  • ian G
    • Nov 2023
    • 7
    Re: Mac A1990 Screen
    I have also heated the screen to 40c using a hairdryer, No Change, put pressure on the edges of the screen (No change) applied a suction cup (1ins) to one area of the screen (No change)
    Regards Ian G
    • PITERPENY
      • Jul 2023
      • 461
      • Ukraine
      You can’t fix this yourself if there is no installation to replace the conductive glue under the cable that is glued to the matrix. Over time, it happens that one contact on the cable comes off. in general, it’s not difficult to fix, but you’ll have to disassemble it, and I don’t recommend doing this without practice, since a microcrack will lead to complete loss of the matrix. and if you have practice, everything is very simple. I often encounter this problem.
      • ian G
        • Nov 2023
        • 7
        Many thanks for the information Piterpeny, stay strong most of the world supports you,
        Regards Ian G
        • PITERPENY
          • Jul 2023
          • 461
          • Ukraine
          Originally posted by ian g
          re: Mac a1990 screen
          many thanks for the information piterpeny, stay strong most of the world supports you,
          regards ian g
          tnx bro
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • ahoonid
            MacBook A1990 vertical stripes on external screen
            by ahoonid
            Hey everyone,
            I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
            The board is neat. Not opened before for sure. Just a little dust, nothing more.
            Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
            06-20-2025, 08:54 AM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
