Proview 19" Back light problem, Replaced Caps already
  • haris2887
    • Nov 2010
    • 6
    hi all..
    i got a Proview 19" monitor with a back light problem
    I have replaced the bulging caps already and at least the monitor turns on now...
    but i cant get the back light going..
    Now i realist the are tow cathodes ( Backlights) in the pannel one at the top and one at the bottom.
    if i disconnect the Top Cathode ( by not plugin the wires into the PSU) i get the monitor going for about 3-4 seconds before it cuts out... (see video)
    if i plug it in It I get scrambled image...(see Video)
    So i think the problem might be in the Inverter circuit somewhere for the top cathode ?
    I am not very good with trouble shooting..
    i have the following Pics..
    note the PCB discoloration..
    Possible problem in the White Square Plugs circuit for BackLight (top right corner)
  • haris2887
    • Nov 2010
    • 6
    Re: Proview 19" Back light problem, Replaced Caps already
    More Videos coming...
    • retiredcaps
      • Apr 2010
      • 9271
      Since this is your first post, you should read the following on how to insert pictures (do not post them inline).
      People will not be happy with megabytes of pictures the way you posted them (they slow down loading), but you can edit them and correct it, please.
      https://www.badcaps.net/forum/showthread.php?t=1868
      Here is an example of the pictures we need ...
      https://www.badcaps.net/forum/showpo...94&postcount=1
      --- begin sig file ---
      --- end sig file ---
      • haris2887
        • Nov 2010
        • 6
        http://www.youtube.com/watch?v=50cWaWW7-Dc
        This is what happens when i have everything plugged normally
        http://www.youtube.com/watch?v=X2nfycVkwNk
        This happens when i disconnect one of the Cathodes for the back-light..
        • Rtech
          • Jul 2010
          • 1095
          Apart from the Large Capacitor, and the small one close to it, behind the Heatsink,you need to change ALL of the rest,not just the ones that were bulging !!! then see what happens,as it still could be a faulty backlight ??
          • haris2887
            • Nov 2010
            • 6
            i have already replaced all the Caps.
            All the Black Caps are new, 9old one were a green color like the small one next to the huge balck one...
            • haris2887
              • Nov 2010
              • 6
              I cant edit the pictures ??
              • bonney
                • Oct 2008
                • 74
                you need to change your CCFL tubes
                • haris2887
                  • Nov 2010
                  • 6
                  Problem Solved
                  All i had to do was swap the Cathode tubes..
                  i was plugin them in wrong..
                  so i plugged the top in bottom plug and the bottom in top plug and BAM... Works First time (total of 4 plug )
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Good. Now BEG Topcat (the administrator) to allow you to remove those huge pictures. What a pain in the ass this thread will be if it's not done.
                    PlainBill
                    • PNI E.
                      tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                      by PNI E.
                      hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                      02-20-2025, 08:36 AM
                    • koby058
                      vostro comes up with back light but no picture
                      by koby058
                      Hi people!!
                      The owner said it showed bad picture once in a while (attached)
                      I see that there is back light but no picture.
                      I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                      Also attached schematic and BDV
                      LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                      07-13-2025, 01:03 PM
                      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                      I am comparing them to a brand new one that I installed
                      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                      I going to let it run for several days before I remount back on the wall next to the...
                      09-05-2024, 06:48 PM
                    • giddyupngo
                      Backlight replacement mess, Vizio V505-G9
                      by giddyupngo
                      Hello, I would appreciate your expertise on this. I have about 5 years experience with copier repair, so I have done a lot of board and component replacement. This is the first LCD TV I tried to repair, and it really humbled me. The issue was that on power on the TV power light would go on and then fade out seconds later, and there was no image at all, screen stayed black.
                      I thought this meant there was a power board problem, not realizing that the power light fading out was by design, probably so the light would not distract the TV watcher. This is not my TV, so I wasn't familiar...
                      02-09-2023, 09:14 PM
                    • karatzdi
                      Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                      by karatzdi
                      I know some might say... just buy another one. Sell it as parts..!
                      So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                      Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                      Spent some time downloading the Service...
                      06-11-2024, 08:38 AM
