Hey guys...I have removed the four screws,tried prying on all four sides....inserting putty knives to hold each side open while working on the next side and nothing seems to work. Is there something else keeping this case closed?
Can't seem to open Acer AL2416W case
Re: Can't seem to open Acer AL2416W case
I guess I should tell you why I'm trying to get inside...I was given this monitor because it quit. When you turn it on the Acer logo comes on for a second or so then the screen goes black. The power light stays green. Using a flashlight I cannot see anything on the screen so I want to look at the components but I can't get it open.
After the screws are removed from the back, I used a flat screw driver to get a
small gap on one corner and just open it with my hands. It feels like its going to
break but it doesn't. I still have that same problem but the green light turns
amber about 2 seconds after the logo shows up.
The Service Manual can be found here. They usually show how to disassemble it.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Mann-Made Global Warming.
- Dr Seuss
Ok got it...there is a small plastic cover over the area where the stand attaches to the computer. This cover pops off and there are four more screws holding the stand and the cover in place. With those screws out, the cover easily comes open. Now for the tough part...........
Now that the monitor is open I can see the three circuit boards....the main board...the power board and the inverter board. I do not see any caps exhibiting bulging or leaking. It does look like the caps on the inverter board board have been replaced because the soldering looks like hand soldering rather then machine soldering.
Any suggestions as to where to go next?
Originally posted by Mike_S456 View PostHere are two pictures of the Power Board with the cover removed
Tentatively we will assume the caps are fine. I would like good sharp pictures of the inverter, top and bottom. Also, what is the part number of the IC directly above the connector?
The IC directly above the connector has 3 lines of numbers stamped on it
First line: 0Z9925GN
Second Line: 51597741G
Third line: 0530A
I did not take any pictures of the back side of the inverter board because the board is a surface mount board. It only has circuitry on the back, no components or thru holes
Originally posted by Mike_S456 View PostI did not take any pictures of the back side of the inverter board because the board is a surface mount board. It only has circuitry on the back, no components or thru holes
P.S. Those are some great pics!
