Can't seem to open Acer AL2416W case
  • Mike_S456
    • May 2010
    • 22
    Re: Can't seem to open Acer AL2416W case
    Yes...you are correct...it was a bad assumption on my part....thanks for pointing that out
    • Toasty
      • Jul 2007
      • 4171
      Elecktrotanya site SUCKS Locked out AGAIN!
      If somebody gets this manual, would you send it to my Yahoo email as an attachment? TIA
      Follow PlainBill on this. Has these diagnosis down cold.
      Uses long tubes U-shaped 530mm tubes. Check test points from Service Manual. One wrong voltage compared to others will point at bad tube or involved circuit. Tubes are very susceptible to cracking either from factory, tube manufacture, or unit was dropped sometime.
      Soldering on inverter caps is factory, as you said. Not fixed by someone. No one recaps with those caps and gray caulk. Look at blue coils below. Same solder job.
      FireFox java SUCKS. - Third time I've lost this posting.
      Toast
      [ Don't be to concerned with the backside. To trace those from top to bottom you really need to have the card in your hands and a bright flashlight to track them. Doing it from pictures on the web is nigh impossible. A lot go top-bottom-top-under something-bottom-top... ]
      veritas odium parit
      • Mike_S456
        • May 2010
        • 22
        There seems to be six backlight tubes used....there are six output connectors on the board.......are you saying that if one is not working they all will not be working?...
        • Toasty
          • Jul 2007
          • 4171
          Correct. I've had 2 of these 24" units, both with cracked tubes. As soon as the inverter controller sees a voltage differential indicating over-voltage or over-current, it trips the unit to off. If you can keep hitting the power button over and over, and see the logo/desktop/whatever, then at least -some- of the tubes are working. As I said, PlainBill has more experience here.
          Toast
          veritas odium parit
          • PlainBill
            • Feb 2009
            • 7034
            Toasty is actually understating the case. An inverter is a constant-current high voltage source usually with over voltage and over current protection.
            The circuitry usually senses the current through all CCFLs and adjusts the transformer drive to maintain the total design current through the CCFLs. (If a monitor has 4 CCFLs rated at 5mA each it will maintain 20 mA total current through the CCFLs.
            Over voltage protection (OVP) shuts down the inverter if the voltage across any CCFL exceeds limits. Since current through a CCFL rises at end of life, Over current protection (OCP) shuts down the inverter if the current through any CCFL rises too high.
            Essentially any anomaly will cause the inverter to shut down. Usually there is a 2 second delay from turn-on until it starts OVP and OCP is enabled.
            I've marked up one of the photographs.
            First step. I've numbered the pins on one of the transformers from 1 to 7. 1 is on the lower left corner, 6 is on the upper right, and is the output. Set your DMM on the 2K ohm scale and measure resistances from pin 6 to the other 5 pins (don't bother with pin 2). You should get a reading in the 1K range from pin 6 to only one other pin. This is the secondary winding. Now measure the resistance on the other 11 transformers. All should match to within 3%. If you find one that is outside this range, stop.
            Next step. This test involves working with potentially lethal voltages. I suggest having an assistant. Note that I have labeled the lower end of C115 as Vsens. Hook up the boards in the normal working layout. Arrange it so your assistant can push the power button. Set the DMM to the 20VAC range. Now, probing from the bottom end of C115 to ground, try to get a voltage reading while the backlights are on. Repeat for C102, C137, etc.
            Report your results.
            Darn!! Can't find a datasheet for OZ9925GN.
            PlainBill
            • Toasty
              • Jul 2007
              • 4171
              #26
              Browsing around I find that the 10 - 100uF/35v caps are suspects also, and since you are here, should be replaced as a matter of course.
              I'd go with 50v caps in either Panasonic FM or UCC KZE series.
              Mentioned also was checking the Q3-Q5 & Q4-Q6 MOSFETs. These can be compared to each other as Q3-4 are the same number, as are Q5-6.
              veritas odium parit
              • Mike_S456
                • May 2010
                • 22
                #27
                Ok..I have completed the first step. I numbered the transformers T1 to T12, 1 being on the far left and 12 being the far right. I made and attached a pdf file of the resistance values I measured.
                I will have to wait until later for the second step to have someone available to help.
                When measuring the voltage, where is the best ground on the board? I was thinking of using pins 6, 7. 8 .9 or 10 on the input connector
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #28
                  Wherever you see a plated screw hole.
                  A working TV? How boring!
                  • Mike_S456
                    • May 2010
                    • 22
                    #29
                    The 3 plated screw holes at the bottom of the board seem to be common to the ground plane (at least they are common to pins 6-10 on the input connector) but not the 3 screw holes at the top of the board
                    • Toasty
                      • Jul 2007
                      • 4171
                      #30
                      Correct, the top three are not ground.
                      veritas odium parit
                      • PlainBill
                        • Feb 2009
                        • 7034
                        The transformers appear to be good. There is a 2% difference between the high and the low.
                        A proper ground point has been discussed.
                        And I have one more test. With the DMM on the 20VAC range, measure the voltage on pin 1 of each transformer while the CCFLs are on. This is the current sense line.
                        PlainBill
                        • dt2rz
                          • Oct 2010
                          • 30
                          #32
                          PlainBill
                          I did the first step but have different results from Mike_S456. Does this mean all transformers are bad? Hope you can guide me what to do next?
                          • Toasty
                            • Jul 2007
                            • 4171
                            #33
                            >>I did the first step but have different results from Mike_S456.<<
                            What scale was your meter set to?
                            veritas odium parit
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Your variation is larger than what Mike_S456, but usually if you have a bad transformer one transformer will be distinctly lower than the others. I don't think that any are bad.
                              Note to others. There was a communications problem on the description of the test. I asked Mike_S456 to test all pins on the transformer because I did not know which pin was the other end of the secondary. In the future, all you have to measure is the resistance between pin a and pin 6.
                              The two tests I suggested above will check for open or aged CCFLs. Do them.
                              PlainBill
                              • dt2rz
                                • Oct 2010
                                • 30
                                #35
                                Thanks Plainbill. I will continue the test when i get somebody to assist me.
                                @Toasty - DMM on the 2K ohm scale
                                • Mike_S456
                                  • May 2010
                                  • 22
                                  #36
                                  Am I performing test 2 and 3 correctly?........at the capacitor I'm reading about .8 VAC when the Acer logo comes on and about .35 VAC at pin 1. Doesn't seem right to me so before I continue I'm asking you. Thanks
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    #37
                                    Different meters, different responses.
                                    With it set on 2kΩ -
                                    A 999Ω resistor would read .999 (.999kΩ)
                                    A 1,000Ω would read 1.000 (1.000kΩ).
                                    So your first row basically matches Mike_S456's results.
                                    Your meter may not go high enough on the 2kΩ scale to reach megohms, but instead may just show a 1. or the OL indication. If you change the meter to the range where it will read ~5 megohms, you'll probably match Mike_S456 on those other legs.
                                    Toast
                                    veritas odium parit
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      #38
                                      ...Note to others. There was a communications problem on the description of the test. I asked Mike_S456 to test all pins on the transformer because I did not know which pin was the other end of the secondary. In the future, all you have to measure is the resistance between pin a and pin 6...
                                      Pin a ?
                                      veritas odium parit
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Originally posted by Toasty
                                        Pin a ?
                                        Typo. The secondary runs from pin 1 (not a) to pin 6.
                                        PlainBill
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          That could be right. Don't be afraid to drop to a lower range. I don't have more that a rough guess as to what the voltages should be. What we are looking for is a difference on the transformers that drive one CCFL. In other words, if 10 of the 12 transformers show .5 - .7 volts on pin 1, but two adjacent ones show .1 volts, that is significant. If 10 of 12 caps measure .8 - 1.3 volts, but the two associated with the same transformers that had a low voltage at pin 1 show 3 - 3.5 volts, that is a positive sign something is wrong with the CCFL connected to those transformers.
                                          PlainBill
                                            09-06-2024, 05:27 AM
                                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:00 AM
                                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
                                            Acer Swift SF314-43-R9ZY + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift SF314-43-R9ZY + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-43-R9ZY + Pack Gold Acer 14'' boardview and SF314-43-R9ZY + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-07-2024, 03:10 AM
