Can't seem to open Acer AL2416W case
  • Mike_S456
    • May 2010
    • 22
    Hey guys...I have removed the four screws,tried prying on all four sides....inserting putty knives to hold each side open while working on the next side and nothing seems to work. Is there something else keeping this case closed?
  • dt2rz
    • Oct 2010
    • 30
    Re: Can't seem to open Acer AL2416W case
    There's another screw at the back of the screen menu buttons.
    • Mike_S456
      • May 2010
      • 22
      I guess I should tell you why I'm trying to get inside...I was given this monitor because it quit. When you turn it on the Acer logo comes on for a second or so then the screen goes black. The power light stays green. Using a flashlight I cannot see anything on the screen so I want to look at the components but I can't get it open.
      • Mike_S456
        • May 2010
        • 22
        Sorry...I did take that little silver one out also that was at the back of the menu screen. I should have included that info on the first post
        • dt2rz
          • Oct 2010
          • 30
          After the screws are removed from the back, I used a flat screw driver to get a
          small gap on one corner and just open it with my hands. It feels like its going to
          break but it doesn't. I still have that same problem but the green light turns
          amber about 2 seconds after the logo shows up.
          • Mike_S456
            • May 2010
            • 22
            I can get a big gap all the way around but it refuses to open....there has to be something else holding it.
            • PlainBill
              • Feb 2009
              • 7034
              The Service Manual can be found here. They usually show how to disassemble it.
              PlainBill
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Look under stickers for screws. [Find soft spot with finger.]
                Look under brakets if not off.
                Also check that the jack-screws [see pic] are not holding it together.
                Mann-Made Global Warming.
                - Dr Seuss
                • Mike_S456
                  • May 2010
                  • 22
                  Ok got it...there is a small plastic cover over the area where the stand attaches to the computer. This cover pops off and there are four more screws holding the stand and the cover in place. With those screws out, the cover easily comes open. Now for the tough part...........
                  • Mike_S456
                    • May 2010
                    • 22
                    Now that the monitor is open I can see the three circuit boards....the main board...the power board and the inverter board. I do not see any caps exhibiting bulging or leaking. It does look like the caps on the inverter board board have been replaced because the soldering looks like hand soldering rather then machine soldering.
                    Any suggestions as to where to go next?
                    • bonney
                      • Oct 2008
                      • 74
                      on the new caps is the solder touching each other?
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        Take a picture of the power board with the metal plate off of it. There's lots of stuff being hidden under there.
                        Ludicrous gibs!
                        • bonney
                          • Oct 2008
                          • 74
                          Q3 and Q4 on inverter board look like they have got hot
                          • Mike_S456
                            • May 2010
                            • 22
                            nope....even though it looks close, my meter says they are not touching.
                            • Mike_S456
                              • May 2010
                              • 22
                              Q4 & Q4 on the inverter board look good...no evidence of ever getting hot
                              • bonney
                                • Oct 2008
                                • 74
                                I would change the ten caps they have been off but they dont look new
                                • Mike_S456
                                  • May 2010
                                  • 22
                                  Here are two pictures of the Power Board with the cover removed
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    You have the 'Two seconds to black' problem. Possible causes bad CCFLs, bad wiring to the CCFLs, bad caps, bad transformer, bad drivers, etc.
                                    Tentatively we will assume the caps are fine. I would like good sharp pictures of the inverter, top and bottom. Also, what is the part number of the IC directly above the connector?
                                    PlainBill
                                    • Mike_S456
                                      • May 2010
                                      • 22
                                      The IC directly above the connector has 3 lines of numbers stamped on it
                                      First line: 0Z9925GN
                                      Second Line: 51597741G
                                      Third line: 0530A
                                      I did not take any pictures of the back side of the inverter board because the board is a surface mount board. It only has circuitry on the back, no components or thru holes
                                      • Wrog
                                        • Oct 2009
                                        • 472
                                        With all due respect, someone who is trying to help you has asked for specific items. If you expect him to continue helping, it might be in your best interest to supply those items. He may want to see the traces on the backside to see what's connected to what.
                                        P.S. Those are some great pics!
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Nitro Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) boardview and Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz,...
                                          09-07-2024, 03:10 AM
