Can't seem to open Acer AL2416W case
  • Mike_S456
    • May 2010
    • 22
    #41
    Re: Can't seem to open Acer AL2416W case
    I'm using a Fluke digital DMM so there are no range settings. After I test one pin I need to turn the monitor off and wait about 30 seconds or the backlights won't come on for those short two seconds. I don't understand that either. I will continue the test when my assistant returns tomorrow...Thanks for the help so far
    • PlainBill
      • Feb 2009
      • 7034
      Just adding a link to a schematic for an inverter using an OZ9925GN inverter controller.
      Sorry it's not the same inverter you have, but at least now we know the pinout.
      PlainBill
      • Mike_S456
        • May 2010
        • 22
        #43
        Sorry..... I had to delay this repair because of some more important work....but I will be back at it tomorrow
        • BShanahan14rulz
          • Aug 2010
          • 20
          #44
          As long as it's open, you might want to think about replacing at least the four caps in the first bank anyways: C34, C35, C36, and C38.
          I'm still a noob, but of the two AL2416W's I've taken apart, those 4 caps were popped on both monitors. I used Panasonic FC's (meant to use FM's), but a word of caution: the ones I used are slightly taller and wider. Instead of 4 inline, I staggered them. Not quite as good as new, but I can live with it.
          • alexanna
            • Mar 2010
            • 1346
            #45
            I just got one of these monitors in, the power LED would come on to recognize a signal from the computer, But I could see no flash of the backlights and I was unable to see an image with a flash light.
            Opening the monitor I noticed no problems with any of the capacitors, all the fuses on the inverter tested good, and I had 24 some volts going to the inverter. I was able to identify the 3.2V Back light on siginal,and it was making its way down to pin 15 of the OZ9925gn inverter controller.
            This monitor uses a different type of CCFL connector than any I had available, I had some good CCFLs out of a 22” monitor, and by changing connectors I was able to substitute 2 CCFLs at a time. Each time I substituted CCFLs I noticed that all of the transformers were able to light the CCFLs briefly.
            After reading the 2 threads on this monitor I tried replacing the 35V 100UF caps on the inverter, and this fixed the problem.
            • jetadm123
              • 2169
              #46
              alexanna: you replaced the 100uf 35V caps with what brand/series? It would seem most of the aftermarket caps are a little larger in diameter than the originals. Did you have any trouble getting the new ones to fit properly next to each other?
              • alexanna
                • Mar 2010
                • 1346
                #47
                I used a 50v 100uf Nichicon PW series, they were approximately 8mm x 10mm, they were installed at about a 45 Deg. Angle to the board.
                I had to modify the cover for the inverter; cut out part of it over the capacitors, and fashion a shield from some spare parts I had to cover the cut out area, and secured everything with a little JB Weld.
                • alexanna
                  • Mar 2010
                  • 1346
                  #48
                  One of the reasons I wanted to present this in the forum is the fact I could not see any indication of a flash of the back lights, and not being able to see anything on the screen with a flash light. But it was clearly lighting my test CCFLs.
                  I am wondering in a case like this if we should suggest checking the BL on signal pretty early in the diagnosis?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #49
                    Member Maxxarcade just posted a youtube video on how to fix this monitor. See
                    http://www.youtube.com/watch?v=Xm0AJ65TGOI
                    --- begin sig file ---
                    --- end sig file ---
