Asus XG32V monitor with lines
  • BMCappelletti
    • Nov 2021
    • 148
    • Brasil
    Hello.
    I have here a Asus 32' curved display showing these lines.
    A short clip of what shows when I turn it on.
    https://imgur.com/a/Z8fyqym
    Here are some pictures of the boards. Visualy they seem fine.
    There are lots of videos on Youtube on possible solutions, but I could not find a similar problem with a similar board layout.
    Any help is appreciated.
    Thanx.
  • Dracken
    • Sep 2024
    • 3
    Hey BMCappelletti,
    I'm currently facing the exact same problem as you with an Asus ROG strix XG32VQ.
    Did you find a solution?
    Did you replace the main board or something else?
    Cheers!
    • BMCappelletti
      • Nov 2021
      • 148
      • Brasil
      Originally posted by Dracken
      Hey BMCappelletti,
      Cheers!
      No luck.
      Listed it as "for parts" and someone bought it. Have no idead what was the issue.
      • Dracken
        • Sep 2024
        • 3
        Ok, thanks for taking the time to reply!
        • Madero
          • Apr 2024
          • 5
          • Austria
          I am currently trying to solve a similar problem on a vg32vq which has the same board. You could try disconnecting the daughter board of the panel from the main left one and see if you have picture on half the screen without the lines. In that case the problem is on the daughter board to the right. If you could send me a picture of the Ic Buck converter Chip on the daughter board with the resistors below it, it would help me a lot.
          If someone has schematics for the board that wokld be great as well
          • BMCappelletti
            • Nov 2021
            • 148
            • Brasil
            Hi. It's been more than a year I posted this.
            I don't have any of it anymore.
            • Balzat
              • Feb 2015
              • Poland
              Hi
              I have exactly the same problem with the Samsung C32JG52QQU monitor
              It has exactly the same LCD panel CY-PN315CGAV1F
              When I disconnect the daughterboard of the panel, half of the screen is displayed correctly
              I am sending a photo of the chip on the daughter board with the resistors below it
              I replaced the G1564 chip with a new one but nothing changed
              looking through a thermal imaging camera, there is no sign of anything heating up suspiciously
              Maybe together we can come up with something
              Click image for larger version  Name:	IMG_20241126_164304.jpg Views:	5 Size:	1.80 MB ID:	3515668
              • Johny Hsu
                • Feb 2025
                • Taiwan
                Hi Madero,
                Pictures for your reference.
                How to check & fix the issue?
                I can follow your suggestions to test.
                Thanks a lot.
                • Madero
                  • Apr 2024
                  • 5
                  • Austria
                  Originally posted by Johny Hsu
                  Hi Madero,
                  Thanks a lot.
                  Hey thanks for the Picture. I am currently still trying to figure out the issue as well. Just fixing some stuff for a hobby and haven't worked on the monitor since. Maybe we can help each other? If you still have the picture I would be happy if you could send it to me. I am right now switching the IC and will check if that will solve the issue. In my case only the doughter board of the panel has an issue but I couldn't find any short, the ribbon cable seems to be good as well, taping the pins din't help either (sometimes some clck has an issue). In my case the picture fades black as soon as I plug in the daughter board. VGH, VGL and AVDD are dropping in voltage as soon as the daughter board is plugged. Especially VGH towards 0v.
                  • Johny Hsu
                    • Feb 2025
                    • Taiwan
                    The follow test data for your reference.
                    I'd buy these two board from LCD broken people.
                    The board no COF cable, so test these voltage just only no connected LCD panel.
                    I'd change all ICs (chipset), but the screen still shown green & some white line, like BMCappelletti's first picture.
                    I think this status not CTRL board & SOURCE board issue, I think it is COF cable fail or panel fail.
                    But I still waiting for your good news, hope you can find issue & fix it.
                    • Madero
                      • Apr 2024
                      • 5
                      • Austria
                      Do you maybe have the resistances of the rails to gnd? I would be interested what resistances you have especially on 12v, VGL, VGH and Avdd, Havdd. Do you have a different resistance on 12v when the mainboard (with the hdmi ports, etc) is plugged to the tcon board as without plugging it in? Does half your screen work when the source board is unplugged from the tcon board? Thank you!
                      What is your resistance on the coil L306 next to VGL1?
                        by momaka
                        03-15-2023, 10:17 PM
                      • myth77
                        ASUS PG27U MONITOR
                        by myth77
                        First, i dont work on monitors only on laptops and that also for a hobby. So, i received this monitor in the title and it was completely dead, and power supply when used was going off to a power protection. I found that one of the voltage regulators for backlight GS9238 is dead, so i replaced it and monitor is working fine now. But...on the main motherboard first thing i tested was a main power rail and after power jack there is one mosfet Nikos PD537BA. The thing is when i tested all pins of that mosfet are shorted in between. Now when i plug the adapter the monitor just goes on. I dont think...
                        03-19-2024, 08:58 AM
                      • reessi
                        ACER BM320 Monitor - Horizonal Flickering Lines After a While
                        by reessi
                        The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                        They are black on the right and gradually fade to nothing on the far left.
                        They start either after 5 mins or up to 2 hours after so annoying for testing.
                        They flicker continuously very fast! With a slight pause milli-second every second.
                        Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                        I tested each half by removing the first the left flex from...
                        06-03-2025, 09:58 AM
                        ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                        This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                        09-07-2024, 02:50 AM
                        ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                        This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
