Acer AL2216w backlight issue
  • tatatoothy
    • Oct 2010
    • 8
    hey
    my 22" acer flatscreen has just pooped out on me.
    The backlight powers on for about 1-2 seconds then powers off. It comes on when you turn it on to see the acer logo. then again for about a second whilst it shows the desktop then it's off. i can see that the desktop is still functional and displayed in the background.
    I replaced all of the 470uf caps on the power board. no other changes have been made. its still doing the same thing. for the record: none of the caps were bulging or looked bad. i figured this was the easiest possible fix and worth a shot.
    before i replaced the caps i disconnected each backlight to see if i could figure out if one of them was busted (4 connectors in total). nothing changed.
    i have a decent multimeter as my disposal.
    i'd love if someone could help me out.
    the number on the board (this is for future forum searchers) is 715g2278-1 . if you google this number you'll find some info on an AOC monitor in polish.
    what's my next step?
    here's a hi-res pic of the power board
  • PlainBill
    • Feb 2009
    • 7034
    Re: Acer AL2216w backlight issue
    Originally posted by tatatoothy
    hey
    Follow the links in my signature to find out how to take good quality pictures, take one of the back side of the board as close to 2000 x 2000 pixels as possible and attach it to your next post. Do NOT post it inline.
    PlainBill
    • retiredcaps
      • Apr 2010
      • 9271
      Rev 0.2 will be up sometime next week if things go well, but see rev 0.1 at
      https://www.badcaps.net/forum/showthread.php?t=10419
      That should give you some ideas for starters. Ask questions if something doesn't make sense.
      PS. Please don't post images inline. Use the manage attachment function.
      --- begin sig file ---
      --- end sig file ---
      • tatatoothy
        • Oct 2010
        • 8
        Here are macro pics of the board both top and bottom.
        Thanks for everyone's help so far
        • PlainBill
          • Feb 2009
          • 7034
          Well, you have some work ahead. I've marked up one of the pictures, here are the measurements to make.
          The first is easy. Hook everything together EXCEPT the CCFLs. Plug 1 CCFL lead into it's socket. Turn on the monitor. Does the monitor light up, even for a brief flash? Disconnect that CCFL lead and hook the next one into it's socket. Again, turn on the monitor, do you see a flash? Repeat for all CCFLs.
          If one CCFL does not produce a flash, try plugging it into the adjacent connector. If it still does not flash, the CCFL (or it's wiring) is bad. If it DOES flash, try plugging and adjacent CCFL lead into that connector. If that one no longer flashes, you have a bad transformer, driver, connector, etc.
          The next test is slightly more complex. With the power off and the monitor unplugged, make the following measurements:
          Set your DMM to the 2K ohm range and measure from A to A', B to B', C to C', D to D'. The readings should be in the 1K ohm range, and within 3% of one another. If you get readings of 'open' for all, don't worry. Try reading the resistance from the point marked Gnd to A, B, C, and D. Again, they should be within 3% of one another.
          If one is significantly different, that transformer is bad, you can stop.
          The next test is rather difficult. You will be dealing with painful and potentially lethal voltages. I suggest you have someone assist you (preferably not someone who would profit by your demise).
          With everything hooked together, set your DMM to the 20 VAC range. Put the black probe at Gnd, and the red probe at Va. Have your assistant hit the power button on the monitor so the CCFLs come on. Repeat cycling the power button several times, record the voltage (readings may vary from time to time). Now repeat the process for Vb, Vc, and Vd.
          The last test is similar. Set your DMM to the 20 VDC range and repeat the process, except measure the voltages at Ra, Rb, Rc, and Rd.
          Report the readings.
          I have circled an IC, U801. What is the part number?
          PlainBill
          • tatatoothy
            • Oct 2010
            • 8
            there are 4 sockets (s1-s4) and 4 cfl connectors marked as upper and lower blue and pink
            s1: Upper Blue + Upper Pink show nothing
            s2: All CFLs flash when connected here.
            s3: all cfls connected do not flash and the acer logo is not visible however the "no input" box is VERY FAINT but possible to see.
            s4: same as s3
            there is an audible, intermittent very high pitched (above 8Khz) buzzy sound when a cfl is connected to s3 and s4.
            A-A,B-B,C-C,d-D: open
            gnd-A: 982 ohms
            gnd-b: open
            gnd-c:989
            gnd-d: 979
            as per your instructions i will stop here.
            PlainBill
            • PlainBill
              • Feb 2009
              • 7034
              s4: same as s3
              gnd-A: 982 ohms
              gnd-b: open
              gnd-c:989
              gnd-d: 979
              Something does not make sense here.
              Please verify you measure from B to Gnd, not B'. If that is correct, look over the solder joints very carefully. The reading indicates the transformer is open.
              PlainBill
              • tatatoothy
                • Oct 2010
                • 8
                PlainBill
                just rechecked. it still reads as open. used the continuity test to verify the leg on top is indeed connected to the solder joint and the connector and all tests well.
                • PlainBill
                  • Feb 2009
                  • 7034
                  I would say that's the problem. Are there any numbers on the transformer?
                  PlainBill
                  • tatatoothy
                    • Oct 2010
                    • 8
                    80gl20t-23-dn
                    darfon 6501f 726041z
                    i did some googling for these numbers and came up with nothing
                    • tatatoothy
                      • Oct 2010
                      • 8
                      hey bill. thanks for your hard work so far. really appreciate it.
                      any suggestion on what to do next?
                      i've googled and googled and haven't found this darfon transformer anywhere. darfons site doesn't work.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        At this point your options are limited.
                        First. I'd pull the transformer if you haven't already done so, and see if by any chance the end of the winding broke where it was soldered to the leg of the transformer.
                        After that, you could try to buy a non-working inverter/power supply board (or non-working monitor) and salvage a transformer from that.
                        Or you could put it on the shelf and use it as a source for parts.
                        PlainBill
                        • tatatoothy
                          • Oct 2010
                          • 8
                          hey bill
                          after taking a look at the underside there was no obvious connection to the windings as they were covered in plastic on that side.
                          i've been looking for broken models but after taking a look at this board i realized that the same model number used different power inverter boards.
                          might be time to sell it on ebay for parts.
                          thank you for all of your help. i greatly appreciate it
                          • mdvickst
                            Hi all. I have an Acer AL216w that has a very similar problem to this one so I wanted to re-open this thread and see if I could solve this problem. I have the 2 second to black issue and a similar ticking noise that is audible.
                            I measured between the legs of the transformers and it only read around 475 Ohms for both. I also think there are only 2 transformers for the back lights as you can see in the attached pictures.
                            I tried plugging in all of the CCFLs separately and the top blue plug and bottom red/pink plug wouldn't flash in any connector.
                            I was able to see the Acer Logo and the "No input Detected" dialog with the other 2 CCFLs.
                            I assume the reading on the transformers, even though it is different than what you said means that they are good so I'm thinking 2 bad CCFLs? I have also inspected all of the caps on the power supply and they look good. I have also replaced all of the electrolytic caps except for the 2 47uf 25V caps which I will when I find replacements.
                            Any ideas?
                            Thanks!
                            Mark
                            • mockingbird
                              • Dec 2008
                              • 5484
                              Can you post a picture of the logic board?
                              • mdvickst
                                Thanks for your quick response!
                                Here you go.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Your board and the OP are totally different. As long as the secondaries are within 3% of each other, they are good.
                                  You may not have 2 bad ccfls. You may have bad wiring. These pics will help you determine which.
                                  http://s807.photobucket.com/albums/y...klight%20lamp/
                                  Also, PlainBill's test above may only be valid for that board because it has 4 ccfls and 4 inverter transformers.
                                  If you have a spare monitor, you can use that spare monitor as a "good" ccfl. You can then stretch the ccfl cables from the Acer to the "good" ccfl and narrow down which ccfl may be bad. See #5 at
                                  https://www.badcaps.net/forum/showpo...1&postcount=14
                                  • mockingbird
                                    • Dec 2008
                                    • 5484
                                    Your PCB is different than the OP. It looks like someone did a hackjob recapping job on this. Let me guess, you bought this used? The reason why I say this is because I see a UCC capacitor in there, which is unlikely to have come fromt he factory.
                                    You will first need to find out which capacitors were in there originally, and when you do, I can list you suitable replacements.
                                    I would also replace the capacitors on the logic board.
                                    Additionally, eventhough it's usually deemed uneccesary, I would go ahead and also replace that large Suscon primary capacitor on the power board.
                                    You will need to know several things about the capacitors. Make, model(series), and dimensions. Take a ruler and measure both the width and length in millimetres.
                                    • heinduplessis
                                      • Jan 2014
                                      • 4
                                      • South Africa
                                      I have 3 of the same monitors, used on my one PC. They're probably 5 years+ old now, and two of them will not come on immediately. One is working fine, one comes on after leaving it on for about 30 minutes and switching it off and back on, the third one needs 2 hours plus in the "on" position and then cycling the power. However this morning it would simply not come on. If I look carefully, I can see it appears the backlight is not working.
                                      I'm not an electrical engineer, but I want to check with you experts weather it's worth while trying something before dumping the monitors in the trash?
                                      Many thanks.
                                      • heinduplessis
                                        • Jan 2014
                                        • 4
                                        • South Africa
                                        Quick note - sometimes, after trying a few power cycles, the backlight comes on for about 100ms, then turns off.
                                        • Cornito
                                          Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                                          by Cornito
                                          Hello Team,
                                          I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                                          Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                                          Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                                          08-08-2024, 08:09 AM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • Cornito
                                          TCL 65C715 backlight issue
                                          by Cornito
                                          Hello team,
                                          I'm back with another topic.
                                          It's a 65C715 TCL tv with backlight issue.
                                          But the problem is a bit strange.
                                          When I took this tv from the marketplace backlight didn't work but picture was ok.
                                          Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                                          Putting all back together the tv worked fine for weeks. => Contact issue??
                                          Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                                          06-09-2024, 02:24 AM
                                        • Mirenia
                                          Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                                          by Mirenia
                                          got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                                          The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                                          If this happened once, then the laptop only runs for a few minutes until restart.
                                          This happens regardless while staying in windows or uefi or in a linux environment.
                                          At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                                          01-05-2025, 05:15 PM
                                        • ahmarzo
                                          Acer laptop battery draining issue
                                          by ahmarzo
                                          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                          Today, 06:39 AM
