Re: Samsung SyncMaster 940T blows inverter fuse
back from the dead. but I have the 940t blue power light comes on but no picture. so I opened it 3 820uf caps were bad replaced them. still same prob power light on no picture. but computer recognizes it as being there just no display. is this related to needing the inveter fets with the part number above? thanks guys
Yours was not blowing a fuse. This one (stevenps) is confusing enough.
I suggest starting a new thread?
With any luck, the schematics we have will match yours.
Is this the one you were talking about on post #111? The tight fit one?
You don't identify the LCD in that post. Is it a 940T?
If not, what is it?
Good shot of the back and identify any IC's please.
Copy and paste all you talked about so far into the new thread.
ToastLeave a comment:
I replaced every last one of them. Sorry, this isn't the recap. I'll try to get a picture of it on tommorow. You think I should replace the big one maybe? I hope I didn't blow an IC. Otherwise I'll have to toss this in the trash.Leave a comment:
That's a photo of the recap? Can't be...?
Ticking is the PWM trying to fire. Sounds like a wrong cap or you didn't replace them all, sans main cap.
Voltages?
Oh well, this recap didn't last long. A few minutes into using it it started making clicking sounds. I attributed this to coil vibration since I removed some tack. Now it won't turn on at all (Like the light won't even turn on, no power whatsoever).
Any ideas what could have blown here?
Is there a chassis number somewhere? I see 2 different ones for the 940T.
My advice for resistance checking was not clear enough. I was trying to suggest a broader scale of checking, rather than a component-by-component check. For example, pick a transformer leg and go back to the 4 BIT IC outputs, or to the power input to the board. It might help narrow this faster. Then, if you found a mismatch, you could go component by component back up the path of the difference.
Do the transformers get warmer on the failed monitors than on the "good" one over the same time period?
>>Getting the old ones off the board was a real pain - they acted like they were glued down. <<
Most likely they were. Otherwise the hot air stream used to solder them could make them move or blow them off. Process is: apply solder paste to all pads and glue dots as needed, mount components, allow paste to cure, solder process.
Better way to take these off with a soldering iron is with Chip Quik and something to apply upward pressure (pin). A hot air station is the best as you can get all the solder liquid and then lift it or twist it to break glue.
Suggestion: Try comparing the good board to the bad ones using an ohmmeter. I had a similar chase in an power supply thread here last year. The problem was finally found by the poster using this method with a new board. Turned out to be a transistor in an area not even being considered. Start at the transformers and work backwards.
Toast
EDIT: Which schematic did you get from Elektrotanya? There are several. Only one I found with the inverter schematic is not the same as yours. Different driver FETs (AM4512C). BUT the inverter Driver IC is a Fairchild FAN7310 and is a 20 pin package. If you look at Page 8, it shows the timing of the outputs. None are supposed to come on at the same time and looks very similar to the 1st trace picture in your post #129.
If it turns out the BIT3195G is bad, I have not found one available other than through a RFQ type of site. They typically won't talk to you unless you need 100 pieces or more.Leave a comment:
Toast
If it turns out the BIT3195G is bad, I have not found one available other than through a RFQ type of site. They typically won't talk to you unless you need 100 pieces or more.]Attached FilesLast edited by Toasty; 11-05-2010, 01:28 PM.Leave a comment:
I don't think R217 is involved there - it looks like inverter IC pin 8 has R316 between it and the FETs, and pin 9 has C213 and C214 in series between it and the FETs. I'll get a better picture, and check if there's a trace running under C213.Leave a comment:
I also got some (hopefully) more useful pictures from my scope. These are comparisons between the good (blue and green) and bad (red and yellow) monitors showing both the pin 8 output from the inverter IC and another signal (one is pin 9, the other is the drains of the FETs). I think the most interesting one is the output from the FETs - instead of being an interesting-looking, square-like wave (like the blue line), the bad monitor has a sine-looking segment (yellow line). I'm not sure what that means or what causes it, but it corresponds to a slight difference in the signal at pin 4 of the FETs. The good monitor is flat in those locations, but the bad monitor shows a slight increase in voltage when the signal should be low (see Pin8-Pin9Gate-U202Drain.png for a comparison of all 3 signals from the bad monitor). Perhaps C213 or C214 is bad?
PlainBillLeave a comment:
I also got some (hopefully) more useful pictures from my scope. These are comparisons between the good (blue and green) and bad (red and yellow) monitors showing both the pin 8 output from the inverter IC and another signal (one is pin 9, the other is the drains of the FETs). I think the most interesting one is the output from the FETs - instead of being an interesting-looking, square-like wave (like the blue line), the bad monitor has a sine-looking segment (yellow line). I'm not sure what that means or what causes it, but it corresponds to a slight difference in the signal at pin 4 of the FETs. The good monitor is flat in those locations, but the bad monitor shows a slight increase in voltage when the signal should be low (see Pin8-Pin9Gate-U202Drain.png for a comparison of all 3 signals from the bad monitor). Perhaps C213 or C214 is bad?Leave a comment:
I received my replacement transistors today, and the replacements did exactly the same thing the originals did. Getting the old ones off the board was a real pain - they acted like they were glued down. I actually melted one of them in half trying to get it off. Either the originals overheated and I overheated the new ones trying to get them installed, or there was nothing wrong with the originals.Leave a comment:
.Leave a comment:
@PCBONEZ:
The 2 caps given, are too tall (30mm). Clearance is limited to 20mm.
I noticed that the Capxon sheet seemed "off", but couldn't place what was wrong. From what I see, it seems they take caps from everyone/everywhere, some from this pile and some from that, just to build a sheet.
QLast edited by Quasar; 10-27-2010, 09:19 AM.Leave a comment:
Shipping is something like $5 via USPS Priority Mail. They do some interesting packaging - they put your caps in a plastic bag, put that in a bubble mailer (they do this part for each part # you order), and put those in a box.Leave a comment:
FK come both as SMD and Radial.
The letter right before 'FK' is different in the full Part Number.
EEUFK = Radial
EEEFK = SMD
EEVFK = SMD
A 10x20mm Capxon KF would be around 1320/.065 or so.
An FC or PW in 10mm would be good enough.
http://search.digikey.com/scripts/Dk...me=493-1832-ND
http://search.digikey.com/scripts/Dk...name=P11223-ND
The Capxon KF data sheet is erratic.
What I mean is using FC and PW for some KF is fine but for others FC and PW aren't good enough.
.Leave a comment:
Ok so here's what I got on Newark per Quasar and StevePS' help, with guidance from Momaka's Capxon Replacement Table.
2 x Panasonic FK 25V 820uF - Newark 32R9027
3 x Rubycon ZL 25V 220uF - 38M3273
1 x Panasonic FC 10V 2200uF - 25M9153
1 x Nichicon PM 10V 1000uF - 65R3529
1 x Rubycon YXG 50V 22uF - 38M6869
This list accounts for what's in stock. That's why I have to mix manufacturers.Leave a comment:
Link to Newark's page on the FK 820s (my edit window expired):
http://www.newark.com/panasonic/eeuf...ial/dp/32R9027
Looks like Newark will be getting this order and not Digikey. How's their shipping costs?
If they say they squeezed it in there, I believe it. There's a lot more trust in their manufacturing.Leave a comment:
I'd trust Panasonic any day. If they say they squeezed it in there, I believe it. There's a lot more trust in their manufacturing.Leave a comment:
Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
I had no problems connecting mosfets and capacitors,...-
08-27-2024, 12:46 PM -
by corrizeHello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping... -
by Michale32086I could have sworn I posted about this before, but I can't seem to find the post..
To whit..
I have a 60LN5400 that came in.. Backlights work fine.. No display..
Traced the problem to the TCON board.. Blown fuse..
Replaced the fuse.. Blows again.. Replaced the fuse again... This time it fries the marked part on the Main Video board...
Got a new Main Video Board.. Replaced the fuse on the TCON..
The fuse is fine and the backlights come on fine if I don't have the cellophane connectors from the TCON to the... -
by dimis7Hi all,
Need some advice to troubleshoot this TV.
PSU blow the main fuse F100, 3.15A.
I replace the fuse with another 3A (but not ceramic) and blows it again after few seconds when i plugged in to the wall, with nothing connected to PSU, just the power cord.
I checked with DMM for dead sorts but didn't found any.
Checked bridge rectifier and seems ok.
Also check main filter cap with transistor / cap / esr tester (the usual cheap transistor testers from ebay) and found ok.
PSU p/n is EAX64405901 (1.6)... -
by jesteraceHi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
- Loading...
