Dell E177FPf No Power
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell E177FPf No Power
    Originally posted by retiredcaps
    Well, that is good news. You may have had a poor solder joint on that cap?
    Thanks for the offer, but I'll pass.
    Perhaps PlainBill can make use with just the eeprom chip from board "A"?
    Let's see, 'A' is the board with an unstable power supply. Yes, I definitely would like that board. Billy66 if you are willing to ship only the power / inverter / logic board to me, PM me and we'll make arrangements on shipping costs.
    PlainBill
    • billy66
      • Mar 2010
      • 124
      PlainBill... no problem.
      But, I do have another issue with the working monitor, that I did not notice at first. The screen is extremely blue tinted. If I bring up the OSD, it is normally colored. So, I first checked my computer with another monitor, not that. I replaced the VGA cable, not that. So I thought maybe I didn't notice the blue color at first due to it not being there... I powered down the monitor, let sit an hour to cool... and turned on and it is still blue. I just didn't notice at first. Any ideas on this one? I assume it is on the video side of the card... where to start looking? I'm half tempted to move all the power supply parts over to the other board to bring it to life... but realize that I'm learning nothing that way. Can someone point me in the right direction? And yes, I have tried to adjust the settings on the monitor...
      Thanks again for all the help.
      • seanc
        • Nov 2008
        • 1319
        You have of course done the obvious and performed a factory reset on the monitor?
        Otherwise, try DVI, assuming it has DVI. Rules out a dodgy VGA port.
        • billy66
          • Mar 2010
          • 124
          Yeah, did factory reset... same. And it is only VGA port. But good idea.
          • seanc
            • Nov 2008
            • 1319
            Do all of the colours display properly, but with a blue tint, or are you missing red?
            Bring up a colour palette in paint to confirm.
            My suggestion after, would be to try re-soldering the VGA port connections.
            A slight anecdote, I have a VGA cable on my KVM with a damaged pin, any machine connected will show up black and white when on a BIOS screen, but works fine once in an OS.
            • jetadm123
              • 2169
              #26
              Have you tried reseating the ribbon cable from the LCD panel to the circuit board. If that doesn't work, try swapping ribbon cables with monitor A.
              • billy66
                • Mar 2010
                • 124
                #27
                I tried reseating the cable... but figured it wouldn't work. The On Screen Display works. i.e. when you press menu you get the options to adjust and stuff... and it looks perfect.
                Maybe I am missing red. When I mad the background all red... it was purpleish lavender? I will try the re-soldering of the VGA port connections.
                • billy66
                  • Mar 2010
                  • 124
                  #28
                  OK, just noticed something with this issue. When I first hook up the monitor to the power cable after sitting for a bit, the color comes on normal. After about 10 seconds of being on, I can see the screen switch to the blueish color. I haven't opened it up yet to check the VGA connections... but this leads me to believe they would be good.
                  • seanc
                    • Nov 2008
                    • 1319
                    #29
                    Wiggling the VGA cable doesn't help?
                    • billy66
                      • Mar 2010
                      • 124
                      #30
                      Nah, it doesn't do anything. I checked the factory settings and the lamp has 24000 hours on it... could there be something to that? Though, I thought when the bulbs start to go or go... it is a pinkish color?
                      • seanc
                        • Nov 2008
                        • 1319
                        #31
                        Yes, things will go pink when the CCFLs are failing.
                        My re-capped 'Proview' monitor with well used CCFLs starts off very pink and gets better as it warms up.
                        • billy66
                          • Mar 2010
                          • 124
                          #32
                          OK. Mine is definitely not pink, but blue. And it doesn't get better when it warms up. Looks like I'll have to pull it apart again.
                          • billy66
                            • Mar 2010
                            • 124
                            #33
                            OK. I've decided to give up on the bluish tint monitor and try to repair board A. Here is a recap of what is and what has been done:
                            Board A... when plugged in, no LED. The transformer T850 clicks on and off... voltage at U850 pins 3 & 7 bounce all over the place (11 -16VDC).
                            Here is what I've done:
                            - Recapped entire secondary side... no changes
                            - Replaced transformer T850 from known good board (no change)
                            - Replaced I850 from known good board... did this cause I850 supplies pin 2 of U850 and wasn't getting anything out of pins 3 or 4 on I850. After swap, T850 stopped clicking. Also, U850 pins 3 and 7 now have 24.8V steady (not sure if this is high. The known good monitor had 16Vs)
                            - Decided to replace U850 from known good monitor as I found that pin 8 on U850 was only giving output of 0.25v and the known good monitor was putting out like 20v or so. This voltage goes to the gate of Q850... Q850 gate on the known good was seeing 3.58v. On the bad monitor, it was only seeing .02v... maybe not enough to turn on Q850?
                            So after swap of U850, here is where I stand:
                            Monitor wont power on. No LED, no picture, nothing. The transformer T850 clicks once or twice (sounds like it is charging up). Voltages are as follows:
                            - Filter cap: 156V
                            - U850 Pin 1- 0
                            2- 2.6V
                            3- 24.8v
                            4- 1.29v
                            5- 4.5v
                            6- 0.75v
                            7- 24.7v
                            8- 0.25v
                            - I850 pin 1- 99.4v
                            2- 98.4v
                            3- 0
                            4- 2.6v
                            - Q850 G- 0.25v
                            D- 155v
                            S- 0.008v
                            Any ideas?
                            • billy66
                              • Mar 2010
                              • 124
                              #34
                              Being this board is an "all-in-one" board with the inverter, power, and logic all on one... there is no cable between the boards... makes it hard for me to find test points. Can anyone point me in the right direction to take some measurements for the 5V, 3.3V, and 12V?
                              Also, should I start another thread for this monitor alone?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                1) D854 - dual diode should read 12V DC on middle pin ore slightly more (my guess)
                                2) 5 legged voltage regulator chip marked 1506 - look up datasheet and see what voltage should be
                                3) U801 voltage regulator
                                4) U802 voltage regulator
                                --- begin sig file ---
                                --- end sig file ---
                                • billy66
                                  • Mar 2010
                                  • 124
                                  #36
                                  1) D854 - seeing 25.4V on the middle leg.
                                  2) U851 Pin 1 - Voltage climbs very slowely from 0 to 0.882Vdc... and then stays there.
                                  2,3,4,5 all read 0V
                                  3) U801 All pins 0V
                                  4) U802 All pins 0V
                                  I haven't looked up the datasheet yet for Voltage reg, but I assume those readings to be bad.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    25.4V DC could be right for this board. If the capacitors to the right of D854 are rated for 35V, then 25.4V DC sounds right. If the caps are rated for 25V, then I believe 25.4V is too high.
                                    PS. There might be another dual diode (that is obscured by the angle of the picture - above R860). It would be facing "up" on the same heat sink as D854. If yes, that should be your 5V diode.
                                    • billy66
                                      • Mar 2010
                                      • 124
                                      #38
                                      Caps are 25V caps... And there isn't another diode on that same heat sink...
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        I missed the comment in post #33 about the 16V DC being good in the other monitor and U850 showing 24V DC.
                                        Sounds like something wrong around that area. Will have to start with post #1 and re-read as I'm definitely getting confused with all the changes made.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          Check diode D856 with your multimeter in diode check function and report the results for both diode measurements.
