Hanns-G HG281D, LCD Monitor no power
  • Mishannya
    Badcaps Junior
    • Sep 2010
    • 31
    Re: Hanns-G HG281D, LCD Monitor no power
    OK. I've just found 3 dry caps (C603,606 and 707). Going to buy repair kit and replace all of them. Thanks to every body for your support.
    • jetadm123
      • 2169
      Make sure your kit includes ALL the caps. I've seen some kits that leave out the small caps.
      • Mishannya
        Badcaps Junior
        • Sep 2010
        • 31
        Thanks for your advice.
        • retiredcaps
          • Apr 2010
          • 9271
          Let us know if new caps solve the problem or not.
          --- begin sig file ---
          --- end sig file ---
          • Mishannya
            Badcaps Junior
            • Sep 2010
            • 31
            I will. Thanks for your help.
            • Mishannya
              Badcaps Junior
              • Sep 2010
              • 31
              Just repaired my Hanns-G HG281D, LCD Monitor. Replacing 3 dry caps (C603,606 and 707 & couple more small one) returned monitor back to normal life. Thanks to every one for help and support. Best regards.
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                Good work. Saving a 28 inch monitor from the landfill is a good feeling.
                • rushstrike
                  • Nov 2010
                  #28
                  I have a problem with this monitor where it takes about 50 tries to get it to turn on. Once it is on everything works perfectly. Is there a good way to test the power supply board? I would like to plug in the AC power and turn on the board without using the monitor's power button. I see that in the back there's a printout that says PSON so I wonder if I can use that some how to turn the board on. Let me know of any suggestion. Thanks.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Did you check the switch?
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Perhaps a little more detail would help. Do you have to hit the power button on the monitor repeatedly to get it to turn on, or does the problem occur when you apply AC power?
                      The power supply in this monitor is a dual design - the standby section of the monitor is always on and takes only a few watts (possibly less than 1 watt). The main section is switched on only when it is active and draws most of the power.
                      The symptoms you describe sound like bad capacitors, and the layout of the power supply looks like it was designed to kill caps!!
                      PlainBill
                      • jetadm123
                        • 2169
                        #31
                        Please post some photos (top and bottom) of the power board per PlainBill's links in Post #30.
                        • rushstrike
                          • Nov 2010
                          #32
                          Yes the switch has been physically checked. It seems to open and close just fine using an ohm meter. According to this post, it seems that the problem is most likely due to the power supply board. If I unplug the AC cord and replug it into the wall, it seems like it has a better chance of turning on than me just repeatedly hitting the power switch. I will take some photos once I am home from work.
                          • rushstrike
                            • Nov 2010
                            #33
                            PlainBill
                            The monitor can sometime turn itself on right when I plug in the AC power. Then sometimes it can turn on when I try to press the power button repeatedly. Once I can turn it on, I can turn it off and on for about 5 times consecutively before it stops responding.
                            • jetadm123
                              • 2169
                              #34
                              My initial guess is the startup capacitor is acting up. It's under that metal cover. Can you remove it and retake the photo?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Like the OP, all his caps looked good (no bloating), but after testing with an ESR meter, he found 3 dry caps and proceeded to switch them all out and save a 28 inch monitor.
                                If you have a multimeter, see if you get stable 5V STB DC (details in previous posts).
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  As is common for larger monitors, there is a PFC front end on this power supply. MORE complication. I would agree with retiredcaps. Do replace all electrolytics, especially the tiny ones.
                                  PlainBill
                                  • rushstrike
                                    • Nov 2010
                                    #37
                                    I think I will try to check the caps first with the ESR meter since I have to desolder this cap in order to remove that metal cover. I dont have a soldering iron with me atm.
                                    • Fatweed
                                      • Feb 2011
                                      #38
                                      Hi there,
                                      Just to add my 2 cents, I had a dead Hanns-G HG281D too, and after following the advice and info here I managed to get this dead monitor working again.
                                      There were 3 dry caps that were measuring low/incorrect capacitance once removed from the power supply, which were C603,606 and 707 also found by Mishannya. (these caps did not look puffy or leak either on inspection)
                                      Many thanks to this great site!
                                      • algomez
                                        • Jan 2011
                                        • 17
                                        #39
                                        I'm in the process of recapping the power board on my HG281D as well. Ordered the caps from Digi-key, on their way now.
                                        Mine turns on for a while (15 mins or so) then shuts off. I can turn it on again and same thing happens except it shuts off within ~10-20 secs.
                                        My power board looks different than yours and has a manufactured date of May 2009. Here is a pic with cap values:
                                        • jetadm123
                                          • 2169
                                          #40
                                          Your monitor is under 2 years old. Isn't it still under warranty? It would be suprising if the cap(s) failed that quickly.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            03-31-2024, 02:12 PM
                                          • mikey5791
                                            Philips 196V3L monitor power led off
                                            by mikey5791
                                            Hi, i was given this lcd monitor last week with the issue of power led blinking. Upon checking the power board, i found 2 pieces electrolytic caps bulged and replaced them.
                                            Later, when i switched on ac power and detected 5v and 15v dc at output pins. But as soon as i pressed on the front power button, the led on power button lights for 1 second and it turns off.
                                            So, i tried disconnect the flex ribbon cable from t con board. But all i got is a white screen with nothing on. I suspect there is something short somewhere that prevent the display being turned on. Can someone with...
                                            01-25-2024, 07:52 PM
