900G power supply? Won't turn on (obvious blown caps)
  • geocrasher
    • Sep 2010
    • 5
    Howdy all, the famous 900G won't turn on. I've disassembled it and am pretty sure that the power supply is shot. I'm not sure how bad it is. I've attached pictures. The caps are bulging and obviously bad. I will replace those, and the F101 fuse as long as I know that this board is worth rebuilding. The way I see it there are 10 caps that all need replacing, the fuse, and I don't know what else.
    I have plenty of soldering experience. I recapped a bad video card the other day and it works great.
    So, how does it look?
    Thanks in advance for the help with this project.
    PS- As I've read in other posts, (yes, I searched thoroughly) I was given this monitor and am interested in repairing it since it is a nice LCD that I could really use. I'd hate to throw it away!
  • jetadm123
    • 2169
    Re: 900G power supply? Won't turn on (obvious blown caps)
    Yes, it's worth the approx. $10 in parts to try getting the monitor up and running. If the fuse tests good, there's no need to change it. Replace the 10 caps (except the large one, as they rarely fail) with good quality low-esr caps.
    • geocrasher
      • Sep 2010
      • 5
      Great! will do. What are low-esr caps? I'm not familiar with the term.
      One thing I forgot to post in the original post. In the picture of the back side, look toward the far right. There appears to be some sort of oxidization on some of the SMT components. Is it anything to worry about?
      • c_hegge
        • Sep 2009
        • 5219
        Caps have a small resistance to current known as ESR (equivilant series resistance) Low-ESR caps are caps where that resistance is very low.
        For this application, you could probably use Panasonic FC seires
        It looks more like residue flux to me. Don't worry too much about it.
        Also, what are the ratings on the caps? and what country are you in? That way I may be able to post some links to good replacment caps.
        • geocrasher
          • Sep 2010
          • 5
          Hi Guys, thank you! I'm in the US. Reno, NV to be specific.
          • jetadm123
            • 2169
            I suggest Panansonic FM or FC caps. FM have better specs and are about the same price if you purchase through digikey.com. You can order the cap using the steps below:
            Here's the best way to order from digikey:
            1) Go to digikey.com
            2) In the "parts search" window type: panasonic fm and select "GO" button
            3) Under the Capacitor heading select "Aluminum"
            4) The first two columns you see are capacitance and voltage. Highlight the value and voltage with your mouse and select the "Apply Filters" button
            5) You'll see several selections available. Here's what to look for:
            a) Look at the quantity available and minimum purchase. If "0" are available, then there's none to purchase. Some selections require a minumum purchase of a 1000 units, which you also don't want. I think you get the picture.
            b) height and diameter. Measure the original caps and compare to what's listed.
            6) If your value is out of stock, go back to the beginning and type in "panasonic fc" and go through the same process.
            7) During the checkout process select USPS First Class shipping, since this will give the best ship rate.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              ESR (equivalent series resistance) is basically the 'resistance' of a capacitor TO AC, that is not attributable to capacitance (uF). [As in it is not Xc.]
              The values of both Xc and ESR are frequency dependent.
              The Frequencies of Ripple encountered due to SMPS action are right around 100 kHz.
              [Probably most have Ripple between 25kHz and 200kHz. Data sheets for Low ESR caps are standardized to 100 kHz.]
              At 100 kHz the ESR has a large affect on the caps 'resistance' to AC and Xc has almost none.
              The Low ESR cap's job is to pass the noise left over from from the transistor switching action in the SMPS to ground. [noise = ripple in this case.]
              A small ESR [small resistance] to 100 kHz will 'short' the 100 kHz noise to ground thereby removing it from the DC power sent from the supply.
              That said:
              It is best to stay as close to the original ESR as possible as generally there are inductors as part of the 'filter' that includes the cap.
              The Inductor and Capacitor's values [uH of the inductor and ESR of the cap ] are chosen so they work together to get the best filtering.
              If you go wild and jump from like .050 ohms ESR to .015 ohms ESR you may de-tune the filter and end up with more noise instead of less.
              It's never good to go to a higher ESR because that will remove less ripple even without being de-tuned.
              FC are a good all around cap for working with monitors [typical grade of the originals] but occasionally there will be an original crap cap with better ratings than FC.
              That's why -if possible[**]- always check the specs on the old caps before choosing replacements.
              If not possible then fail-safe to FM.
              [**] Some crap brands simply don't have data sheets available.
              Mann-Made Global Warming.
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Use 105C caps. [Temp rating.]
                - Dr Seuss
                • pedro
                  • 199
                  • AUSTRALIA
                  And as the ESR increases, so does the heating of the cap from I2R due to the ripple current. The heating accelerates the ageing (drying out) of electros and soon you have either a failed cap or a failed component in the affected circuitry. So while too low an ESR *can* in some cases create a problem, too high an ESR is fairly sure to.
                  Friends don't let friends buy Samsung ....
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Probably but it depends on the caps involved.
                    As the ESR increases less Ripple current passes through the cap making the I in I²R smaller and since I [or I²] is usually bigger than R, I would expect the total of I²R to go down.
                    But:
                    Typically caps with a higher ESR rating will have a lower Ripple current rating too.
                    The Ripple current rating is how much Ripple current the cap can pass through without over heating internally. [Basically it's based on I²R.]
                    You can check.
                    The Ripple current rating is given in the same data sheet as the ESR.
                    When choosing replacement caps you want:
                    - The same or lower ESR.
                    - The same or higher Ripple Current rating.
                    - The same or higher voltage rating.
                    - The same uF.
                    Some people play around with uF values.
                    It's a rare case where it's not easy to get caps with the same uF.
                    If you MUST change uF then it's better to go up one standard value because uF goes down as caps age.
                    - Dr Seuss
                    • pedro
                      • 199
                      • AUSTRALIA
                      I originally thought that way too, but it seems to generally not be the case in switcher filters. You have an AC source (the ripple component on top of the DC) which is effectively a current source - directly related to the DC current component from the upstream switcher or whatever - so the ripple current doesn't drop off materially as the ESR rises.
                      But:
                      Yup.
                      - The same uF.
                      More "yup".
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        What you originally thought was correct.
                        Nothing changes the creation of the ripple quantitatively but the cap is NOT the load.
                        -> The cap is in parallel with the load.
                        When you raise ESR the total Ripple current created at the switchers doesn't change but what isn't going through the cap to ground is now going through the load to ground.
                        Raising ESR reroutes Ripple to the load.
                        That amount of Ripple Current that gets redirected to the load isn't heating the cap by I²R anymore,
                        it's heating the load by I²R instead.
                        - Dr Seuss
                        • PlainBill
                          • Feb 2009
                          • 7034
                          This is picky as heck, but wouldn't it more correct to say that it's doing useful work in the load?
                          In the meantime, the total power dissipation in the system decreases with a lower ESR capacitor.
                          PlainBill
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Well it does do useful work, but with unwanted consequences...
                            A working TV? How boring!
                            • PlainBill
                              • Feb 2009
                              • 7034
                              You don't want a working monitor?
                              The load - the logic card, the LCD panel, and the inverter draw whatever power they need to operate as long as the ESR of the filter caps is low enough to keep the ripple down to satisfactory levels. It doesn't matter if the ESR of the caps is right at the critical point, or if the caps are perfect - let's say 1/10 of the critical level; the load is going to be drawing the same current. However, caps at the critical level are going to be dissipating more power than perfect caps.
                              Now, I wouldn't expect to see a major savings on your electric bill, but I would expect to see the monitor running at a lower temperature.
                              PlainBill
                              • pedro
                                • 199
                                • AUSTRALIA
                                Sorry, I ain't gonna let that pass without comment.
                                The switcher output will have two components - the (wanted ) DC and the unavoidable AC.
                                The amount that gets "re-routed" away from the cap will depend on, for want of a better term, the ... (AC-coupled) ESR of the load. The cap is what provides by far the greatest contribution to the overall shunt impedance at switcher frequency - that's its role. Quadrupling the cap's ESR will not halve the current through it - do the simple maths. Say - for the sake of simplicity - 1 A of ripple with a cap of 0.1 ohm and a load with an (AC) impedance of 10 ohms at switcher freq. Then approximately 99% of the ripple current passes through the cap, I²R dissipation ~100mW.
                                Double the cap's ESR to 0.2 ohms - now about 98% of the ripple current is shunted by the cap. Dissipation? I²R now a tad short of 200mW.
                                You could also do this experimentally by sticking say a pair of 0.1 ohm resistors in series with a known good (measured) low-ESR cap. Stick a DVM across one and monitor the (obviously AC) voltage as you apply a short across the other one. You may be surprised.
                                Anyway, if you don't believe me that's your choice, but it won't change my view.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  PlainBill
                                  How is AC Ripple doing 'useful work' in a DC load?
                                  Like for instance, a Processor.
                                  - Dr Seuss
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Yup
                                    At 99% going through the cap you have 1% going through the processor.
                                    So you'd double the ESR.
                                    At 98% going through the cap you now have 2% going through the processor.
                                    Twice as much Ripple going through the Processor.
                                    - Good Plan!
                                    Let me know if it even boots with 200 mA Ripple on your CPU.
                                    - Dr Seuss
                                    • pedro
                                      • 199
                                      • AUSTRALIA
                                      Yup
                                      Yup. And only a poofteenth less than before through the cap. You're slowly catching on.
                                      - Good Plan!
                                      FFS the numbers were chosen to make it easy_for_you_to_follow.
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        I was never confused. I haven't changed a thing.
                                        I'm not sure why you're confused.
                                        Perhaps it's your English comprehension.
                                        The Ripple that doesn't go through the cap goes through the IC [load].
                                        Less through the cap -> more through the load.
                                        Not sure why you can't comprehend that. It's simple.
                                        Psst - Ripple is AC.
                                        ESR doesn't affect the DC.
                                        DC is irrelevant to a discussion about Ripple.
                                        ESR doesn't 'care' if the DC is 5v or 500v.
                                        - Dr Seuss
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • captain150
                                          by captain150
                                          03-16-2025, 07:34 PM
                                        • cheeky2
                                          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                          by cheeky2
                                          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                          06-15-2025, 05:12 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
