Vertical and Diagonal lines on Dell SE198WFPf
  • George Ortiz
    • Oct 2009
    • 51
    I just got a dell SE198WFPf that was given to me today. Connected the monitor to my computer. Monitor powers up fine for both analog/digital modes. I am getting both vertical and diagonal lines moving from left to right.
    I have never seen this on a monitor before. I don't want to tear apart yet,
    not sure if monitor is under warranty. Monitor was manufactured in 2008.
    Just need some ideas for repair if not under warranty.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Vertical and Diagonal lines on Dell SE198WFPf
    Is there nothing but the moving bars on the screen, or do the bars overlay the picture? If there is nothing on the screen but bars I would suspect the refresh rate or the resolution is set incorrectly. If the display (desktop) is present but the bars overlay it, I would suspect one or more bloated caps in teh power supply.
    As I frequently say, one picture is worth a thousand words. My signature includes links on how to attach pictures.
    PlainBill
    • George Ortiz
      • Oct 2009
      • 51
      Thanks again PlainBill. There is a display and the bars are overlaid on it. I'll check on the power supply.
      • Borse2008
        by Borse2008
        • There’s
        07-15-2025, 04:55 AM
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
        by momaka
        03-15-2023, 10:17 PM
      • Falki
        Colorful LCD Vertical Lines on Samsung ue55es8090
        by Falki
        Hello there, ive recently found an older 55inch Samsung SmartTV.
        Sadly it has vertical lines at the left and one line in the middle-right.
        I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
        I have factory resetted the TV as well but also with no luck.
        I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
        A similar issue has been posted as well but also with no actual response ...
        08-12-2025, 04:19 AM
