Westinghouse Monitor Fading Colors
  • DavidTomen
    • Sep 2010
    • 17
    Hey Guys: Enjoyed searching the forum this afternoon looking for a solution to my monitor issue, and alas - seems I may have another problem.
    This is a Westinghouse L1916HW that I've had for a couple of years with a Darfon B092-XXX inverter board. It worked beautifully for what it is until about a week ago when I powered it up ... The screen was washed out with faded colors and a green tinge overall. There seems to be a shimmer to the display as well. The image is clear enough to be legible but I can't use it because it kills my eyes. I spend 12 - 14 hrs a day on this thing for work.
    The monitor is hooked up to a HP Pavilion d4vt-1020usa laptop with a perfect display.
    I took the monitor apart and see no issues with blown caps although there is discoloration under a Nikos Mosfet. I intend to replace all the caps, and that Mosfet if I can figure out how to find one, but ...
    Does anyone here think that there may be another issue with this monitor exhibiting what I described above? Looking forward to your feedback.
    Cheers,
    David
  • jetadm123
    • 2169
    Re: Westinghouse Monitor Fading Colors
    Welcome to the forum! Please post some clear photos of the power supply, logic board and display per the link below:
    https://www.badcaps.net/forum/showthread.php?t=1868
    Possible problems:
    Caps. If a filter cap has failed, it might be putting out an unstable voltage to the logic card, which could cause unusual behavior.
    Logic card could be bad.
    LCD panel could be bad.
    Loose/bad ribbon cable connecting logic card to lcd panel.
    Post the photos first and give people a chance to look it over.
    • retiredcaps
      • Apr 2010
      • 9271
      Also, please state if you have a multimeter and if you know how to use one to measure voltage and resistance.
      PS. Don't post pictures inline as they slow down the loading of pages.
      --- begin sig file ---
      --- end sig file ---
      • DavidTomen
        • Sep 2010
        • 17
        Hi guys. I do have a multi-meter but will likely need a little coaching on how to use the dang thing. I'm attaching the pics. There is a mosfet (Nikos P2804ND5G) that is a little suspicious that is located next to the green "Tested OK" sticker. I only say that because the back side of the board is discolored in that area.
        • jetadm123
          • 2169
          The P2804ND5G mosfet is responsible for generating a sine wave voltage, which is required by the inverter tranformer to generate the high AC voltage required by the backlights. This mosfet does run HOT and since the board itself is being used as a heatsink, it will get discolored over time. So, unless you're having trouble with the backlights, leave it alone.
          I suggest you piece the boards back together and start taking some voltage measurements at the 8-prong plug. Measure for the 5V and 12V outputs. As for the logic (video) board, one of the larger 3-legged chips on the right side of the board is a voltage regulator, probably marked XX1117-33. See if you can locate it.
          • DavidTomen
            • Sep 2010
            • 17
            Thanks for the quick reply. One thing that I neglected to mention. I hate my multimeter. What is a good, inexpensive multimeter that I can pick up at Sears or Home Depot?
            • retiredcaps
              • Apr 2010
              • 9271
              Some discoloration is normal due to heat from the mosfet.
              Put your multimeter on DC Voltage. If you have a manual range one, put it on 20V DC.
              Put your black probe in COM and red probe in voltage.
              Put your black probe onto a ground screw on the logic board. Put your red probe on the power to logic board connector. Record voltage on each pin (or leg) and report them. At least one of them should be stable 5V DC.
              Your logic board picture is low resolution, but it looks like there are 2 voltage regulators on the far right hand side. They will be designated with the letter U.
              Again, with black probe on the ground screw, measure each pin on the voltage regulator. Also, we need the part number for each regulator.
              Report all voltage readings.
              • retiredcaps
                • Apr 2010
                • 9271
                Does this washed out color start immediately after power on? Or does it happen after a few minutes or use?
                • DavidTomen
                  • Sep 2010
                  • 17
                  The washed out color starts immediately after power on. It get progressively worse after about a minute and then stabilizes. Everything is legible but faded. And there seems to be a shimmer, or - I don't know how to explain it. Flickering over the entire screen?
                  • jetadm123
                    • 2169
                    Some of the symptoms (flickering) you describe can be caused by bad caps. If you want to take a chance (without having done any testing) go ahead and replace them (except for the large one). This board uses very few caps and would cost you under $10 (including shipping). No guarantees that this will solve the problem.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      For flickering, there is a small chance your problem is like this one (post #140)
                      https://www.badcaps.net/forum/showth...?t=9343&page=7
                      Replacing the large cap for Aruba worked because of fluctuating voltage on the big cap. And the big cap had very poor uF (0).
                      • DavidTomen
                        • Sep 2010
                        • 17
                        Logic Board Voltage Regulators:
                        50117
                        K-G
                        73822
                        Pin 1: 0V
                        Pin 2: 3.3V note: is not connected as the other two are
                        Pin 3: 4.74V
                        L1117LG-1.8
                        XB52J0286
                        Pin 1: 3.3V
                        Pin 2: 1.8V
                        Pin 3: 0V
                        Logic Board Pin Connectors:
                        Top row:
                        Pin 1: 4.99V
                        Pin 2: 0V
                        Pin 3: 0V
                        Pin 4: 0.04V
                        Bottom row:
                        Pin 1: 4.99V
                        Pin 2: 4.99V
                        Pin 3: 0V
                        Pin 4: 0.06V
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          All the voltages for the connector pins and voltage regulator seem normal. 5V, 3.3, and 1.8 are fairly common for a logic board. Replacing the caps might solve your problem, but it is only a guess. I have no hard evidence.
                          For a multimeter, I like my Meterman 15XP, but a similar one (Meterman 30XR) can be found on ebay.com for $12 USD + shipping.
                          http://cgi.ebay.com/Meterman-30XR-A-...item5889bc8cf5
                          Dave L Jones, at the eevblog, does a $50 multimeter shootout. It is 50+ minutes and I love his rants!
                          http://www.youtube.com/watch?v=ZoeUgMFLyAw
                          edit: Having first hand experience, do NOT buy any of those cheap DT830B like cheap < $5 multimeters on ebay.
                          • DavidTomen
                            • Sep 2010
                            • 17
                            Thanks for the advice on the multimeters. I'll be ordering the caps today and report back once those arrive and are installed.
                            Cheers,
                            David
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Just re-read post #11 re big cap. If it makes sense, you might want to include that in your cap order.
                              PS. I have no experience with the seller on ebay for the Meterman 30XR. Meterman, is a brand "name" in the multimeter world.
                              • jetadm123
                                • 2169
                                Cheers,
                                David
                                Make sure you order low-esr caps.
                                • DavidTomen
                                  • Sep 2010
                                  • 17
                                  That I am.
                                  • DavidTomen
                                    • Sep 2010
                                    • 17
                                    I rec'd and installed all the caps with Panasonic except for the big one. I expect that one to arrive in the next few days.
                                    The flickering seems to have disappeared from the display, but the colors are still washed out. This happens as soon as the monitor is powered on.
                                    I've tried adjusting colors, brightness, etc. with the buttons on the side of the monitor as there does not seem to be a way to make adjustments using the laptop with a VGA connection. I have ordered a DVI-D to HDMI cable from Amazon which I hope will allow me to use the controls offered by the AMD M880G with ATI Mobility Radeon HD 4200 in the laptop.
                                    I have a feeling that adjusting the controls is not the issue. Anyone got any other ideas?
                                    Cheers,
                                    David
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Other than replacing the big cap, did you try another VGA cable or another source to rule out those as suspects?
                                      • DavidTomen
                                        • Sep 2010
                                        • 17
                                        I tried in on my wife's Dell desktop PC which uses a Dell LCD monitor. The display remained the same.
                                          by momaka
                                          03-15-2023, 10:17 PM
                                          Westinghouse L2210NW LCD monitor - bad caps repair
                                          by momaka
                                          Here's another LCD monitor repair: Westinghouse L2210NW.
                                          Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                                          I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                                          Pictures of the monitor outside/case after a brief...
                                          01-11-2021, 01:14 AM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
