Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
  • glutton4punishment
    • May 2013
    • 81
    Samsung synchmaster 226BW.
    Before I replaced 5 caps, the screen was dim.
    Sometimes it wouldn't turn on.
    I opened it up, and found 4 bad caps in the pwr supply section.
    I unfortunately installee one backwards, i.e. wrong polarity.
    When I turned it on, I head a loud pop, and I quickly shut it off.
    The replaced caps are 3 860uF 25V's, and 1 330u 35V.
    One of the 860uF blew.
    I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close to 950uF, so I figured it was close enough to 1 kuF)
    Now, it:
    1. shows no signal detected (the signal's fine, check w/other monitor)
    2. the menu buttom doesn't work.
    Does anybody think replacing the 1000uF cap will help?
    What else should I be looking at to explain my problems?
    Thanks!
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected"
    If you had 5 bad caps before, where were they and what (brand and series) were they replaced with? Same with the PSU board - what brand and series did you use for the new caps.
    Using the 1000 uF cap in place of the 820 uF cap shouldn't be the issue behind the problem you have.
    Could you post top and bottom side pictures of the power supply and logic board?
    I suspect the menu button not working could be a different issue now - perhaps bad solder joint, bad front panel cable, or damaged button board / cable assembly from taking the monitor apart twice.
    The signal not getting detected could be from any remaining bad caps on the logic board. Hence why I suggest to post pictures of both boards so we can see what you are seeing.
      • May 2013
      • 81
      Thank you for your reply, momaka!
      I'm confused about what the problem is.......but I don't think it's my cap replacement.
      I can get a very poor quality VGA pic.
      While the VGA cable/signal is input, the menu buttons on the monitor work
      But no DVI signal recognition at all.
      And menu buttons don't work when DVI is plugged in.
      I've used other monitors, and the DVI signal is good with other monitors.....
      When the DVI is connected, I don't even get a start up boot screen, and I've looked in the BIOS for settings, to no avail.
      BUT I am sure that I had the monitor working on the DVI side before I changed the caps.....
        LCD LED TV Service Menu Codes
        ALL LCD LED TV SERVICE MENU CODES
        Service Menu Code with Board Name
        China Universal Board / Jumper Board Service Menu Code
        Changhong Ruba Service Menu Code
        Ecostar LED TV Service Menu Code
        Orient LED TV Service Menu Code
        Haier LED TV Service Menu Code
        TCL LED TV Service Menu Code
        Samsung LED TV Service Menu Code
        LG LED TV Service Menu Code
        Videocon LED TV Service Menu Code
        Supra LED TV Service Menu Code
        Toshiba LED TV Service Menu Code
        Symphony LED TV Service Menu Code
        Veste/ LED TV Service Menu Code...
        10-31-2024, 03:58 AM
        by momaka
        03-15-2023, 10:17 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
      • Rick_1234
        LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
        by Rick_1234
        Good evening, gentlemen.
        I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
        To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
        https://drive.google.com/file/d/1L6S...ew?usp=sharing
        Things I tried
        - Bought a new AC adapter thinking that was the problem but the problem...
        06-22-2024, 04:44 PM
        Wise Wing F199 19'' LCD monitor - recapped
        by momaka
        Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
        I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
        When I saw the Craigslist post, I wasn't...
        08-24-2020, 10:58 AM
