Iiyama VisionMaster 405 (S705MT) full of G-Luxons
  • Rainbow
    • Aug 2005
    • 1371
    I have an Iiyama VisionMaster 405 monitor (model S705MT) bought in 2002 (made in 2001). It was working fine (except for the DDC which never worked) - but it has a strange problem now. It looks OK in high resolutions (1152x864@85Hz) but is very dim in lower resolutions (like standard text mode).
    When I power the computer up, I see last part of the POST, then the white Windows ME logo which goes dim slowly. After switching to high resolution, the brightness goes up slowly back to almost-normal level. If I switch to full-screen DOS prompt, I see normal brightness for a moment and then it dims - exactly like during boot. The OSD menu is dim too. When I adjust the brightness and contrast to MAX values, it's blurry and really does not look nice.
    I opened it up today just to see if there aren't any bulged caps. All caps are G-Luxon - but they all look OK, not even a slightest sign of bulging...
  • Chris1992
    • Apr 2005
    • 561
    Re: Iiyama VisionMaster 405 (S705MT) full of G-Luxons
    Weird.... Why are you running WinMe? and what's DDC?
    The great capacitor showdown!
    • Rainbow
      • Aug 2005
      • 1371
      WinME - because that's the latest version where all the hardware (SCSI scanner, SB AWE64, Bt848A video capture card) and software (DOS games ) works properly.
      DDC = Display Data Channel = plug&play for monitors. I traced the SDA and SCL signals from the VGA cable all the way to the microcontroller (or whatever that is - many pins and has metal shield/heatsink on top) - so either the microcontroller is bad or is not correctly programmed.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        is the hv generated independent of h sweep?
        if not look to the s correction area.
        thats the mosfets that switch caps to retune the h out stage.
        • Rainbow
          • Aug 2005
          • 1371
          Today, the monitor was running and suddenly poofed and then produced silent hissing, even for a while after turning off. The picture on the screen was normal. It smelled like a bad cap, however. So I opened it and found bulged G-Luxon 2200uF/25V. I took it out and not only it's bulged but the rubber from the bottom is half way out and leaking electrolyte. So I replaced it with 2200uF/35V Taicon taken from 1995 monitor - so it's not a new badcap but still nothing very good most likely. It works now, no new poof
          But it didn't solve the original problem - that still remains the same. I was unable to find any service manual or schematic.
          • Rainbow
            • Aug 2005
            • 1371
            And the photos
            • Rainbow
              • Aug 2005
              • 1371
              Of course it was caused by bad caps. The 6.3V heating voltage was too low - started at 1.8V after power up and slowly rised to 3.2V (and maybe a bit more). It was caused by bad C924 (100uF/16V @85 degC G-Luxon showing 100ohms ESR) in 6.3V power supply. It was placed inside the heatsink of LM317. Replaced with 470uF/16V @105 degC and no more brightness problems
              • yanz
                • Nov 2004
                • 910
                congrats! that small 100uf caps could be evil. i replaced them on some mobo (arround pci or bios jumper) with lxz 680uF and no more restart problem (unable to restart from OS or unable to wake up after power outage).
                days are so short when you actually do something..
                • mikey5791
                  Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                  by mikey5791
                  Got this working ips led monitor by the brand of
                  Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                  Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                  09-04-2023, 03:50 AM
                • tuantu01
                  IIYama NH55HP No Audio
                  by tuantu01
                  I have iiyama brand computer. Modem NH55HP currently does not recognize the sound card. Looking forward to support in bios. Sincerely thank you...
                  02-13-2025, 09:16 PM
                • EthanMai
                  RAZER RZ09-0330QEM3-EARLY 2020 "It's starting very slowly and needs cleaning."
                  by EthanMai
                  MODEL :RZ09-0330QEM3
                  MBNB : CH551_MB MP V4.0 20200303
                  SSN : BY2025M02304135
                  PN : BLADE 15 STUDIO EDITION -EARLY 2020-RZ09-033
                  Thank you for your help. It needs cleaning; it's starting very slowly.
                  Thank you
                  Sincerely,...
                  07-16-2024, 10:13 AM
                • p2computing
                  Samsung un55ks800df - Display slowly degrades
                  by p2computing
                  I have a Samsung UN55KS800DF
                  When I turn the TV on the picture initially looks great
                  After 10 seconds or so, the bottom of the screen starts to show issues and it slowly creeps upward
                  Eventually the entire display is ghosting and distorted. If I power the TV off for a few minutes and power it back on, the cycle repeats with a good display that slowly degrades.
                  I have attached an image of the display after about 3 minutes of being powered on
                  Thanks in advance for all you do for us!...
                  12-16-2022, 01:35 PM
                • tony359
                  Use of a Variac to slowly power up equipment
                  by tony359
                  I have an old Apple II monitor to restore and I do have a big variac. I've always wondered whether a variac is a good idea to power on equipment which has been unpowered for (likely) decades?
                  When it comes to analogue stuff, I suppose it's ok and I'm probably going to see the device slowly coming back to life with a lower voltage applied.
                  But I suppose this won't work for devices with digital components in it as they won't work unless the proper voltages are applied?
                  In case of an old monitor, it is safe/good for the monitor to...
                  10-13-2023, 02:47 AM
