LCD Monitor Service Menu
+ More Options
Posts
  • dasjeetu
    • Jul 2010
    • 5
    Hi!
    I am reparing a 15" LCD monitor which is using a TSUM15AL-LF-1 MCU IC, the problem with the monitor is that "display is dim", contrast control dosent work, where as the Panel CCFL and inverter board is ok, have checked it with a good monitor.
    This monitor is of indian brand "HCL", but made in china, OEM i guess.
    Do anyone know how to display the service menu. And what can the problem with the monitor, i have googled for the service codes, no hope..
    No datasheet of the TSUM ic, i heard its a topsecret ic.
    Attaching a pic of the controller board.
    Thanks.
    Please help...
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: LCD Monitor Service Menu
    Attachment didn't stick.
    Mann-Made Global Warming.
    - Dr Seuss
    • dasjeetu
      • Jul 2010
      • 5
      sorry, attaching again
      Kindly check and please help me out.
      Thanks,
      Jeetu
        LCD LED TV Service Menu Codes
        TCL LED TV Service Menu Code
        LG LED TV Service Menu Code
        10-31-2024, 03:58 AM
        by momaka
        03-15-2023, 10:17 PM
      • tusiime
        How to access Vizio m652i-b2 service menu
        by tusiime
        The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
        So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
        Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
        09-15-2023, 09:57 AM
      • intercepter
        JVC LT-32CA120 service menu
        by intercepter
        I have JVC LT-32CA120
        Board:Vestel 17MB171
        I need rotate screen.It is possible in service menu and how to enter service menu?
        Thanks.
        12-10-2024, 10:29 AM
      • sohail5307
        I need how to open this Dell service menu option in dell latitude e6420
        by sohail5307
        I need to open service menu of Dell laptops like image in attachment
        Ignore my English
        I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
        01-13-2023, 05:56 AM
