Dell 2005FPW no DVI. Eeprom problem?
  • qwerty`1
    • May 2021
    • rulinka
    Hello
    I have problem with my display. All analog inputs are ok. Problem is with DVI.
    When I connect the cable, the monitor goes into sleep mode (amber LED). All insecure capacitors have been replaced. The voltages are normal. I found out that the EEPROM from the 24C02WP (U105 on logic board) system may be damaged, there are two of them, one next to DVI, the other next to D-SUB.
    If anyone has a dump of this chip, please share.
    Could it be from a different monitor?
    Dell 2005FPW Monitor.
    Image of logic board
    https://ibb.co/SsMsNVd
  • Borse2008
    by Borse2008
    • There’s
    07-15-2025, 04:55 AM
  • toti24
    (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
    by toti24
    dell precision m4600 laptop
    i7 2760qm
    8gb ram 750gb HDD
    intel hd 3000 integraded and nvidia quadro 2000m
    pleasea bear with me english isnt my language and ill try to be as clear as possible
    note i live in mexico in a very small town..
    thank you.
    laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
    the brick happened when i was installing win 10 using usb.
    used rufus and officia microsoft.iso
    it finished copying files from usb...
    03-06-2022, 08:39 PM
  • SDNarcia
    Dell 15R-5521 keyboard problem (KBC?)
    by SDNarcia
    Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
    As additional information,...
    07-20-2024, 10:47 PM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
  • Achille15
    Dell N5110 problem
    by Achille15
    so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
    03-29-2025, 04:41 PM
