correct way to connect bare speaker wires into spring clip terminals?
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    i recently bought a logitech z607 surround system. however, its giving me grief. when i first connected it, it only had sound coming from the front right speaker. after a great deal of fiddling and reseating the speaker wires into the spring clip terminals, i finally had sound coming from all 5 satellite speakers.
    however, the sound still gets cut off intermittently if i move the speakers, subwoofer or move/touch the speaker wires on the back of the subwoofer. so i wanna ask what is the right way to connect bare speaker wires into spring clip terminals?
    i googled for the answers but the problem is they dont say whether u insert the whole length of the wire into the spring clip as far as it will go inside the terminal including the insulated part of the wire? or do u just insert the bare metallic part of the wire and leave the insulated part of the wire outside the spring clip terminal? thanks.
    i just wanna know if the problem is just pebkac or the speakers are really faulty and its the fault of the manufacturer for making such a poorly designed and built speaker system and maybe rma it or sell it?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: correct way to connect bare speaker wires into spring clip terminals?
    Bare wire in, insulation out. If there is intermittent sound with movement, perhaps there are dry joints where the terminals meet the PCB.
      • 31262
      i would crimp ferules onto the wires or tin them with solder,
      i'v seen to many problems caused by those stupid "terminals" with strands of wire sticking out.
      • spiros.p
        • Dec 2020
        • 89
        • Greece
        when i have conections like this over the years i solder piece of wires drill the chassis and screwed speakons or binding post conectors.a life time solution��
          • 31262
          well yes, 4mm posts or 6.3mm jack sockets are good - -but most people dont want to mod the equipment
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3266
            • Singapore
            sry, i forgot to mention that logitech did indeed tin the wires together so they form a single conductor strand of wire about 1mm or less thick so its 20awg speaker wire or so.
            but i've read that spring clip terminals can accept either bare speaker wire or pin connectors from the speakers into the spring clip terminals only. anything else like binding posts, banana or spade are sketchy and may not be an acceptable connection for spring clip terminals.
            and even if i mod the connectors, it may not resolve the issue if the actual problem is bad solder joints on the pcb like diff said.
            yes, modding the equipment voids the warranty. opening up the subwoofer to fix the bad solder joints also voids the warranty.
              • 31262
              it could be a break in the wire under the insulation - if it is then it's probably at the speaker end
              • spiros.p
                • Dec 2020
                • 89
                • Greece
                i do the mods after warranty time.if is dry joint on spring clip terminals under warranty is it to early for dried joints?i mean after years is going to dry the joint's.or is a factory fault.
                • langbaobao
                  DIY 3D-Printer WSON8 Pogo Pin Adapter
                  by langbaobao
                  Hi.
                  I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
                  I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
                  01-08-2024, 05:58 PM
                • Delicieuxz
                  I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                  by Delicieuxz
                  I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                  Here's an audio clip of the sound coming from my speakers:
                  https://vocaroo.com/16HaryHwTx78
                  I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                  11-15-2023, 09:50 PM
                  Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                  The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                  Securing a good thermal interface between...
                  10-07-2024, 04:35 AM
                • Dannyx
                  Wire twisting tool for small wires - ideas ?
                  by Dannyx
                  Good day folks. Recently, I started doing more and more alarm system installs which involve dealing with a ton of small wires which are part of 4 to 12 core alarm cable. To make my installs as clean and neat as possible, I twist together the individual wires whenever possible to make braids like in the picture. It takes a lot of time and wears on my fingers really quickly, to the point where I actually developed a blister on my index finger from all the twisting. This got me thinking if there's a tool designed to braid small wires like this. I know there is something for twisting together solid...
                  08-23-2020, 06:29 AM
                  by SMDFlea
                  Bad...
                  09-02-2021, 04:40 PM
