Amplifier PSU & Oscilloscope Advise
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    Hi All,
    I have been trying to do some measurements on a a small TDA2030 chip amp using a Siglent scope.
    I've been powering the amp with a cheap Chinese HANMATEK HM305 bench power supply.
    The problem is high frequency noise on the output of the amp when powered with the the bench supply.
    If I power it using 2x 9V batteries the noise goes away.
    So my question is what can I do to reduce the noise from the PSU?
    Is there a filter circuit I can use to help this situation?
    Many thanks.
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Amplifier PSU & Oscilloscope Advise
    could try bypass capacitors . or even better filters .. i can't see the power supply from here never mind what's inside it ..
      • 31015
      put ceramic or film capacitors across the power rail at the amp
      • Nevillet
        • Sep 2019
        • 272
        • United Kingdom
        Thanks guys.
        Pete: what kind of filter? could you direct me to a circuit or product?
        STJ: What kind of cap values are we talking about?
        This is the PSU: https://www.amazon.co.uk/gp/product/B0855N2FGY
        Thanks for your help.
        Neville
          • 31015
          try 100nF ceramic or film
          AND 220uf electrolytic in parallel
          ceramic/film deal with very short high frequency noise, the electrolytic deals with general stuff
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            filter capacitor like already suggested
            • Nevillet
              • Sep 2019
              • 272
              • United Kingdom
              Many thanks. I'll report back..
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                wondering about adding a choke if needed later .
                • Nevillet
                  Marantz PM34 amplifier repair advise
                  by Nevillet
                  Hi All,
                  I have a Denon PM34 HiFi amplifier that presented with no output on the right channel.
                  On examination the main drive Darlington transistor pair was faulty together with a smaller NPN driving them.
                  I've obtained the matching transistors but have not soldered them in place and would like some advise before I do:
                  The faulty componants are:
                  Q762 2SD1894 Darlington NPN
                  Q764 2SB1254 Darlington PNP
                  Q752 2SC3419 NPN
                  My question is why did they blow in the first place and are there any componants I should...
                  04-27-2023, 10:34 AM
                • Francesc V.
                  Tele-master AS-20 amplifier. No output sound, just noise
                  by Francesc V.
                  Hi:
                  I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
                  I've checked fuses and all are ok.
                  I've continued with capacitors:
                  • The main black one should have 4700uF, but it has lost half of its capacity during these years.
                  • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
                  The 4 transitors are perfect. Desoldered and tested individually.
                  There are also components which I don't know exactly what they are....
                  02-16-2023, 07:55 AM
                • tony359
                  by tony359
                  11-28-2023, 05:18 AM
                • MegaZAC
                  Onkyo TX-SR805 noise in one channel
                  by MegaZAC
                  Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                  Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                  There's some logic behind it. As soon as I select an input I get only left...
                  04-23-2025, 10:09 PM
                • Francesc V.
                  Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
                  by Francesc V.
                  Hi:
                  I've realized that one of the channels of this amplifier has no proper sound.
                  This is the signal at the speakers output.
                  As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
                  Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
                  07-15-2025, 01:33 AM
