Klipsch RSW-12 subwoofer won't power on
  • scubabuzz
    • Aug 2022
    I have a Klipsch RSW-12 subwoofer that will flash the LED red when the power switch is turned on and once in a while will create a pop out of the speaker. It does not blow the fuse so I am assuming this is probably a power supply issue. Does anyone know if there is a service manual and/or schematics available for this unit?
  • R_J
    • Jun 2012
    • 9588
    Re: Klipsch RSW-12 subwoofer won't power on
    Yes there is a Monitor Audio schematic, do a Search with the model number and see if it is the same as yours
    • scubabuzz
      • Aug 2022
      Thanks R J,
      I did look at the post for the MA subwoofer but it doesn't look anything like my Klipsch. I also saw a tear down photo of that unit and the circuit boards didn't look like the ones in my Klipsch either. Thanks for you reply.
      • R_J
        • Jun 2012
        • 9588
        There are schematics for the RW-10 and RW-12, I don't know how close they might be. Maybe post some pictures of the boards.
        There is also a RSW-15 available that might be close.
        • scubabuzz
          • Aug 2022
          Thanks R J,
          Are the schematics kept in a specific location on this site? I did a search for RSW-15 as well as RW-10 and RW-12 and I saw some posts about the RW-10 and RW-12 which included a service manual but nothing on the RSW-15
          • R_J
            • Jun 2012
            • 9588
            Here is the RSW-15 service manual
            • tibimakai
              • Jan 2012
              • 3680
              There are some great videos on Youtube, specially from Supreme Innovations LLC.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • Gjackson
                Air-conditioning unit power supply failing to power up
                by Gjackson
                Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                01-08-2022, 09:24 AM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
