Philips HTL2193b/98 Can't Power On
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Good day guys... Need help on Philips HTL2193b/98 can't power on either in the touch pad or by remote..
    Findings
    input adapter is good 32 volts..
    low voltage in EUP3490 regulator ic output is rated 5v 3amps to power the mains and standby voltage
    https://www.badcaps.net/forum/attach...6&d=1656677319
    EUP3490 is an adjustable voltage regulator .9 to 15volts
    present reading is just 4.1 volts
    what i did is pull out the eup3490 and power it using a 5 volts supply.. the system works fine.
    maybe a resistor or capacitor decrease or increase its value or maybe the regulator its self is defective.. if someone has the HTL2193b/98 schematics I'll truly appreciate it.. Thank for reading my post.
    • 21679
    Re: Philips HTL2193b/98 Can't Power On
    heres the service manual https://www.eserviceinfo.com/downloa...s_service.html
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Originally posted by SMDFlea
      Thank you very much sir.. you're a life saver..
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
        09-06-2024, 05:59 AM
      • supermattch
        HP 15dy-2021nr wont power on mystery volts
        by supermattch
        Hi everyone.
        I am diagnosing my personal laptop, because it wont power on and no leds light up.
        At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
        Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
        09-23-2025, 12:13 PM
      • CurtisC
        Philips 75pfl5704/F7 No sndby power
        by CurtisC
        Hello everyone. I'm brand new to the group. I'm trying to fix this Philips 4K TV. I have minimal experience with most of this so forgive me if I don't understand half of what is posted on these forums. I'm trying to find my way through it.
        Basically I got the TV from a previous owner who said it just died on them. So I wasn't there when it broke. It will not power on, no lights, no backlight, no sound.
        The output of the power supply has a 27 pin connection to the main board. Pins 18-27 (labeled P-On+20v) are the only pins reading power at 12v each. The pins marked ALL+3.3v, which...
        04-01-2023, 11:53 PM
