Cambridge Audio Azur 551P MM Preamp - No output
  • mediaman083
    • May 2021
    • 9
    Hello everyone!
    Recently my Cambridge Azur 551P stopped putting out sound after years of great music. After testing with my Fluke meter, there is no voltage present from the AC adapter at all. I had another AC 12V 300ma adapter to test with (the original AC adapter is 12V 500ma) and so I did.
    Unit powers up, but there is no buzzing at all when touching the line input cable from the turntable. I am somewhat new to circuitry, but I do know enough to look for blown/bulging caps. I only saw one that was looked ever so slightly puffy in the power supply section, but after testing with an ESR meter and the Fluke meter, none of them seem to be terribly out of range. All of the diodes seem good upon first check.
    I am at a loss on where to look next, or what I should be looking for. Any help would be greatly appreciated, as I would love to get this unit back into service soon.
  • bowerbird980
    • Apr 2022
    Re: Cambridge Audio Azur 551P MM Preamp - No output
    In your second picture; the diodes and 'lytics (capacitors) are a bridge rectifier and power supply. First thing I would do is make sure you are getting +/- Voltage Rails. Measured form GND you should see something in the neighborhood of +8VDC on R42 and -8VDC on R43.
    • bowerbird980
      • Apr 2022
      Next step:
      If the voltage is sagging feel around for something getting warm.
      If it looks okay check the voltage at the supply pins of the op-amps (IC's). I can't read the part# on your pic so just google them. Probably dual op-amps, so the supply pins are 4 and 8. (count from the dot counter-clockwise)
      • mediaman083
        • May 2021
        • 9
        Hello again!
        Thank you for the previous response bowerbird
        So I checked the voltage on R42 and R43. They are as follows:
        R42: +3.6v
        R43: +0.5v
        I also checked the op amp's which are Texas Instruments NE5532's.
        Both are identical with pins 4(VCC-) at +0.9v and pins 8(VCC+) are both at +2.1v
        Nothing is getting warm as far as I can tell, but I did notice when I plug in the adapter that after unplugging and powered on.. the led will just slowly fade out. It would never do that before, just would shut down immediately.
        I also found out there were some cold solder joints for the switch itself, so I went ahead and fixed that first but it didnt seem to be of any help.
        • FrancescoV
          Onkyo HT-R390 no sound output, video output ok
          by FrancescoV
          Good morning everyone,
          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
          The firmware reported is the following:
          M:1.00/11107BLP
          D:?.??/????????
          O:1.00/11107AL
          The DSP firmware given the question marks seems corrupt.
          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
          05-11-2025, 02:59 AM
          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
          I bought this from an eBay seller but unfortunately they only had one
          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
          I bought three of from them to also make battery packs with this output power limit in mind
          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
          04-23-2025, 05:50 AM
        • smurtz
          Cambridge Audio Stream Magic 6 - Power Supply
          by smurtz
          I have here a Cambbridge Audio Stream Magic 6 which does not power on.
          When opening the case the PSU appears to be faulty:
          IC1 (ICE3BR0665J), D2, the rectifier bridge, C15,C16 are dead and T2 is fried:
          I found the schematics of the PSU in the cambridge Audio CXN Service guide which uses the same:
          My problem is that I cannot find any info on T2 (SG01323) which seems to be a choke. Anyone knows how I can find a replacement & the value of that choke ?
          Thanks very much in advance...
          12-20-2024, 02:40 PM
          Corsair CX750M [Model 75-002019] - burned output toroid inductor
          by momaka
          Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
          So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
          09-19-2021, 08:44 PM
        • CoppellTVRepair
          Troubleshooting PFC with SPC1012T not raising output
          by CoppellTVRepair
          It has been a long while since I posted here to ask anything....hope you can help.
          I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
          I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
          03-09-2025, 10:38 PM
