ZLX12P , Electro Voice monitor speaker schematic please
  • zen
    • 511
    Hi all
    This is my next repair project .
    There are a string of resistors connected in parallel that are visibly burnt . ( see picture )
    I suspect they are all 1R in value , but would like conformation before proceeding .
  • lotas
    • Jan 2016
    • 4900
    • Russia
    Re: ZLX12P , Electro Voice monitor speaker schematic please
    Yes, all resistors are 1 ohm
    • zen
      • 511
      Thanks very much Lotas
      • zen
        • 511
        Customer finally gave me the go ahead .
        Replaced all the 1R resistors mentioned
        Q1, ST Electronics 20N95K5 , S/C
        Also replaced control chip , Texas Instrument 3845B , with one i hope is the ST Electronics equivalent UC3845BD1.
        • zen
          • 511
          R26 ( 01A ) O/C
          Replace with a 100R .
          Can anyone confirm this is correct ? , as schematic showing as 150R , but assume that's a slightly different revision of the board .
          • lotas
            • Jan 2016
            • 4900
            • Russia
            R26-101- 100 Om
            • zen
              • 511
              Hi Lotas , thanks
              The 101 is the one i used to replace the original 01A .
              • lotas
                • Jan 2016
                • 4900
                • Russia
                01A - 101 = 100 Om, and about which one you wrote that it was at 150 Om.
                • zen
                  • 511
                  Ok , thanks .
                  Now working & on test .
                  • zen
                    • 511
                    Also removed cheap glue on board indiscriminately used over the electronics ,plus replaced the 2 yellow looking thermal pads on same heat sink as FET replaced , as they seemed to have started to break down , which potentially may have been the root cause of failure .
                    • Ali.kh
                      • Aug 2023
                      • Iran
                      hi , please post a photo of the input board ic3,4,5,6,7, unfortunately, the input signal has a problem, the op amps are burnt, if possible, send a pdf of the schematic of the input board, thank you
                      • GerryT
                        Electro Voice SXA series 100 or 250 powered PA speaker Schematic needed
                        by GerryT
                        Does anyone happen to have a schematic for the amplifier for an Electro Voice SXA series 100 or 250 powered PA speaker?
                        09-17-2023, 10:12 PM
                        by momaka
                        03-15-2023, 10:17 PM
                      • keepread
                        Dell monitor PSU vs Dell laptop PSU
                        by keepread
                        Hi there!
                        Someone gave me their old monitor, it's Dell S2715ht.
                        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                        10-30-2025, 04:45 PM
                      • corrize
                        Voice recorder for blind persons Milestone 311 - Whistle in the speaker
                        by corrize
                        Hello, I have 2 voice recorder to repair. Same issue : whistle in the speaker, but the sound is good with the headphones (via jack audio plug).
                        Built in year 2000, I guess that could be the (yellows) capacitors ? What do you thing about that please ?
                        (I found the specs : tantalum-polymer capacitors 100uF 10v 10%.)
                        09-14-2025, 02:46 PM
                      • wattage
                        AOC AG493UCX 49-inch monitor - Firmware request
                        by wattage
                        Hello Badcaps Community,
                        The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                        07-13-2025, 04:41 PM
